Swr issue
Discussion in 'CB Radio Forum' started by h82bbad, Mar 18, 2019.
  1. h82bbad
    h82bbad Light Load Member
    69
    90
    Nov 18, 2017
    Michigan/ Chattanooga Tn
    I'm having a problem tuning my swr with a 5 foot firestik II. With the adjustment screw all the way out my swr is still higher on 1 than 40 (1.89 on 1 and 1.45 on 40) I'm guessing I'll need to install a spring underneath the antenna or find a longer screw? Tried a 7 foot firestik and same issue. Every other antenna I've tried has been the opposite. Ideas? Suggestions?
  3. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    After adjusting the screw are you putting the red cap back on top of the antenna? Are you checking the SWRs with the doors closed?
  4. h82bbad
    69
    90
    Nov 18, 2017
  5. J Rich
    363
    380
    May 28, 2018
    Atlanta Ga
    Please give more details on the truck it's on. 1 antenna or 2. New coax?
  6. h82bbad
    69
    90
    Nov 18, 2017
    2014 cascadia, mirror mount, new coax. Single antenna.
    Antennas tried
    Wilson 2k (high swr)higher on 40
    Wilson 4 foot (higher on 40)
    K40 4' was also higher on 40
    The firestik is the only one that has shown lower on 40 vs 1
  7. h82bbad
    69
    90
    Nov 18, 2017
    Btw 18' of coax, 980ssb radio
  8. J Rich
    363
    380
    May 28, 2018
    Atlanta Ga
    Be sure you excess coax is not coiled together. There are a few others here that are very familiar with the Cascadia hopefully they will chime in shortly and be able to get you straight.
  9. Ridgeline
    22,719
    123,163
    Are you using an external meter?
  10. h82bbad
    69
    90
    Nov 18, 2017
    Using the built in meter on the radio. I ran the coax, it is uncool going from one side of the truck to the other.
  11. Ridgeline
    22,719
    123,163
    The radio meter may be the problem.
