SWR issues
Discussion in 'CB Radio Forum' started by jakem49, Jan 25, 2013.
  1. jakem49
    jakem49 Bobtail Member
    21
    Nov 15, 2012
    i am running a cobra 29 ltd with blue tooth and 2 4ft firestiks i have an external SWR meter and it says its 3.5 on 1, 20, and 40. also my antenna light glows red when i have the mic keyed, i have 20 ft of radioshack coax.....(i know thats a mistake) and a T coupling for the dual antennas....the radio is currently on its way to delaware to have an rfx-75 installed and an alignment done.....anybody have a clue what could be wrong here?
  3. handlebar
    handlebar Heavy Load Member
    Right off the bat, did you use a proper dual antenna harness, or just two regular runs of 50 ohm coax and a T-connector? If the latter, you're presenting the radio with a 25 ohm load, which is a 2:1 SWR *at best*, assuming everything else is perfect. No amount of fiddlage with the antennas will fix the SWR with the bad match that the existing coax arrangement provides.
    Hopefully whoever does the RFX installation has a spectrum analyzer and a calibrated signal generator, instead of just a cheapie wattmeter and a DC voltmeter to tune with, or the final product is likely to have a numb receiver and generate spurs all over the band.
    But since the antenna light is on before the RFX installation, see if you can borrow a box-stock CB while the '29 is off to the shop and fix whatever is going on with your antenna system. F'r instance, take one of the antenna coaxes off the T-connector and plug just that one into an SWR bridge and see if you get a good match. If you do, then you've apparently got the wrong cabling arrangement for dual antennas. But you can take advantage of this time to tune the two antennas for best match individually, *then* buy a proper "co-phase" harness to use the antennas together.
    Then, once the RFX/29 arrives, if you show a problem, you can be pretty well assured that something has gone awry with the Cobra that you sent off.
    Hope that helps,
    73
    jakem49 Thanks this.
  4. jakem49
    21
    Nov 15, 2012
    helps a whole lot i will sure try that, and when i get the antennas tuned i will
  5. EZ Money
    EZ Money Road Train Member
    Handlebar is dead on as usual....
    It may be better to run one antenna and go as long as possible,and new RG8x coax.
    I have never had much luck with the short Firestick antenna as far as getting it tuned right.
  6. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    i have never cared for a fiberglass antenna.
  7. EZ Money
    Me either......once you go steel whip you never go back...lol!:biggrin_25524:
  8. murph
    murph Light Load Member
    77
    10
    Jan 22, 2010
    I'm assuming you're sending it to R&R Communications? I was there today to drop off a couple radios. Russ is a really nice guy. I walked in and there were about 6-7 guys just hanging out shooting the bull. It was like walking into a barbershop were everybody just hangs out and no one gets a haircut.
  9. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Is there room at R&R to get a truck and trailer in? I heard its tight for parking.
  10. MsJamie
    MsJamie Road Train Member
    Radio Shack coax isn't as bad as it used to be. The old stuff was so bad that I know of a drive-in owner that used several hundred feet of RS RG-58 attached to a dummy load for their FM transmitting antenna. It worked nearly as well as the blue "leaky coax" they were supposed to use, and was a lot cheaper.
  11. anotherjoe
    anotherjoe Medium Load Member
    390
    194
    Jan 8, 2013
    I always had high swr with my ranger in a t600 . I found a francises long whip helped alot . also cb shop in missouri should me a trick nobody ever does. He took his swr meter and had a good reading of 1 . My meter on the radio said almost 3 . So he took the radio in the shop opened it up and demagnitized the swr inside the radio. He basically hooked a ground wire off the swr when ever he make an adjustment in the radio. Once it gets magnitized it will always be off and hard to lower . You will spend your check trying to get it lower it wont work. So demagnitize the swr before you wast alot of money
