Tag axle
Discussion in 'Heavy Haul Trucking Forum' started by me myself and I, Jan 23, 2024.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    I'm looking to buy a truck that has a tag axle. I don't need tag axle. Is there a market for used tag axles? And is removing them as easy as undoing bolts and plugging air lines?
    W923 and Another Canadian driver Thank this.
  3. Idaho MTN Driver
    Idaho MTN Driver Bobtail Member
    40
    79
    Jan 22, 2020
    Yes, unbolt and plug airlines. It will be heavy so make sure you have a way to support it as you unbolt it. If it’s been on the truck a while you might need to bang on it with a sledge to loosen the mounting brackets from the frame after the bolts are out. And yes, should be easy to sell if you’re reasonable with price.
  4. W923
    W923 Road Train Member
    1,415
    4,379
    Feb 28, 2022
    What make and capacity
    I might buy for the right price
  5. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Well I've finally seen that truck, and it's a steerable axle. Made by W&C. 13.2k, disc brakes and new (cheap) tires. It's on 4yrs old truck, so I assume it's that old. If I buy the truck it will be available
    Another Canadian driver and W923 Thank this.
  6. W923
    1,415
    4,379
    Feb 28, 2022
    That would be of some interest
  7. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    It's available. Got 22.5 low pro Yokohama tires on aluminum rims. And it's in N Illinois.the
