Tail light problems
Discussion in 'Ask An Owner Operator' started by Georgiaboy 1975, Oct 19, 2021.
  1. Georgiaboy 1975
    Georgiaboy 1975 Bobtail Member
    I have a 2001 freightliner FLD 120. My problem is with the right turn signal. I have everything on the back of the truck but the right turn signal. If I unplug the light and check with a test light I have a right turn signal. But as soon as I plug the light up no right turn signal. I've changed the light out and same thing is happening
  3. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Did you check the ground side of the plug or just the power side?
    GYPSY65 Thanks this.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    Agree
    If you’re grounding the test light to the trailer it won’t detect a break in the actual ground wire needed for the light
  5. Georgiaboy 1975
    Test light it grounded to frame of the truck.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Attach the test light to the same ground that connects directly to the bulb. I bet that ground is your issue. You can also run a new ground wire to the bulb from wherever your test light is grounded at to verify.
