Taillight wiring
Discussion in 'Volvo Forum' started by Helowrenchturn2, Feb 22, 2014.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Does anyone know which wire coming through the firewall Is for the tractor tail lights?? I don't really feel like inspecting the entire harness so I'll just run a new wire
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Wire at pigtail at back of cab should be hot.
  4. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Ok. Thx. I didn't know there was one there
  5. MICH 6.0
    MICH 6.0 Bobtail Member
    6
    Mar 1, 2014
    Check the wiring harness on the back frame rail right under the angled metal piece and just ahead of the brake lights , mine has chaffed and had to splice a section in. I think the wiring harness is about $100 or less.
  6. brianw123
    brianw123 Bobtail Member
    24
    Oct 29, 2013
    Most of the trailer wiring issues we have had has either been in the pigtail from the tractor to the trailer or underneath the cab, there is a spot not that far from the back of the cab where there are several harness connections, the wires seem to chafe right around those connections. I'll try to get a picture later.
  7. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Actually figured it out a cpl days ago. Turned out to be a bad butt connector at the rear
  8. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    No pun intended.
