Tandem question.
Discussion in 'Ask An Owner Operator' started by Boundtransport, Sep 11, 2019.
  1. Boundtransport
    Boundtransport Light Load Member
    70
    18
    Nov 1, 2018
    U.S.A.
    How accurate is this photo? And if so what if you have that bad that block a specific hole? Another question I had a driver says he’s been driving for 3 years never uses scales...says this works for him. 1st and 2nd gold anything over 40klbs 3rd 4th and 5th golden holes.. for loads under 40klbs?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    You are responsible for measuring Kingpin to axle distance in various states.
    Even though this trailer apparently makes it idiot proof to do so, you will want to measure to the smallest wheelbase such as CA (If you are going that way) and put the tandems there.
    For my experience I never bothered. The weights were legal whatever distance they had to be in order to be legal going east after loading with one exception, never all the way back on 53's unless last resort in Wyoming winter storms.
    Boundtransport Thanks this.
  4. PE_T
    PE_T Road Train Member
    There is probably some truth to it, but I remember hearing from Stevens Transport that CA and FL are known for enforcing it, while the rest wouldn’t care much, unless you’re actually loaded and the tandem looks too far back. Some scales have measurement markings next to the scale, so they can easily measure it.
    Numb and Boundtransport Thank this.
  5. PE_T
    From my experience, loads under 30k, you should be fine with tandems all the way forward. However, if the load is mixed, it is possible that they placed the heavier pallets in the back. For loads over 40k, I’m usually fine between holes 1-3, but if they load you to the very back of your trailer on a 40k+ load, then you will probably have to move the tandem further back. There have been times I’ve had to move it to the 10th hole because of the way it was loaded.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Man, that diagram has a lot of holes. I have a new Utility reefer and it only has about 10 holes. I can't be further back than the first 3 holes to run legal in California.
  7. Brandt
    Brandt Road Train Member
    4,619
    6,347
    Sep 17, 2012
    If it over 40,000 I would scale it. Especially since f the company it pay for it. We were told in California and Georgia the fine for being over the bridge law is more then being over axle weight. The trick to California is load the trailer just like a 48foot trailer. You need 5 empty feet in back of trailer it scale out at the CA bridge law.
    jammer910Z Thanks this.
  8. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Load disbursement varies, and forklift drivers couldn't care less.. for the most part.
    If it's over 40k... scale it.
    Is it really worth saving $11.50 ?
    I eyeball it, and pressure gauge it correctly over 99% of the time, even when I load 44,500.
    Get the CAT tix and say, "Another wasted $11.50".
    But, it could have been off.
    PE_T Thanks this.
  9. Numb
    Numb Crusty Curmudgeon
    4,296
    10,181
    Jan 30, 2012
    Charlotte, N.Carolina
    "the tandems".
    there are actually 2 sets. the tractor has a set also.
    I know,,"but everybody says it this way", "that's how my trainer said it". "but, those are the drives", yes, the the drive TANDEMS.
    old gazzillion miler rant over, thank you for your time.
  10. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    Might be correct. Might not. God knows I've pulled a couple trailers that had the 40' sticker about 5 feet too far back. All the way up is about the only position that will always be legal lengthwise, but beyond that it's like X1 said: your job to pull out the tape measure.
    I will add that if it rolls in CA, it rolls in the entire rest of the lower 48. FL might think they gotcha, but if it rolled in CA then FL is SOL. (Not sorry to the folks at the Grand Ridge inspection station, BTW. This Swift is 100% legal, thanked very much)
