Tank problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Feb 3, 2023.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    2009 international transtar 6 wheel tracktor.
    ISM Cummins alison auto,
    Only drawing fuel from drivers side tank passenger side is full?
    I found a clogged vent and cleared it and verified its clear by blowing into hose and hearing it in the tank.
    I can't see any valves on it to isolate the tank so I'm stumped...
  3. Gridaxe5588
    Gridaxe5588 Light Load Member
    125
    168
    Nov 23, 2022
    Have you checked the cross over tube from tank to tank?
    Rideandrepair and earnies2 Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,538
    6,611
    Aug 26, 2014
    Some IHC's used a electric fuel pump to pump fuel from the right tank to the left. System uses sending units in each tank and computer decides when to turn it on and off. Ours had a bad fuel pump.
    Look where your fuel lines go. Others are duel draw and dual return.
  5. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I will look again but I didn't see one. I did notise the 2 lines on top of each tank along with a sending unit in each tank.
    Rideandrepair and BoxCarKidd Thank this.
  6. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    So if I follow the fuel lines there should be a pump?
    Would there possibly be a fuse for this?
    Rideandrepair Thanks this.
  7. Big Road Skateboard
    6,931
    39,152
    May 2, 2021
    2 things, it's either nor returning to 1 tank, or not sucking from one tank. You can usually see return fuel with the engine running, or remove the return from the tank and run into a bucket. See which side returns faster.
    You can do the same with the suction side.
    Not sure about an electric pump, but that truck is not familiar to me. Usually you have 2 suction lines from tank to a tee. And 2 return lines. Normally your return will have a splitter where both lines from the tank attach. The splitter controls equal fuel diversion, and if mounted leaning, will return more to the lower leaning side.
  8. BoxCarKidd
    4,538
    6,611
    Aug 26, 2014
    If you have two lines to each tank that would be duel draw duel return. No pump.
    earnies2 and Rideandrepair Thank this.
  9. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Almost every time I have ever had this issue the tank that is full is not sucking out due to trash or who knows what in it. I have found little tops to oil caps, panty hose, candy wrappers.. We had one in the shop one day and my dad (R.I.P.) took the line off the tank that was not sucking fuel out and put his mouth on the line and tried to suck fuel out. Well it was clogged so nothing came out. He blew in it and tried again and got a mouth full of diesel. I laughed at him and asked what did he expect. : )
  10. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I looked in the fuse pannle and the fuse for the pump was missing I replaced it and everything is working tanks equalized..thanks
    blairandgretchen Thanks this.
