Tarheel Screwdriver Help (Hammies)
Discussion in 'CB Radio Forum' started by wc5b, May 19, 2008.
  1. wc5b
    wc5b Medium Load Member
    322
    52
    Nov 5, 2007
    Flint, MI
    [FONT=times new roman, new york, times, serif]I am having issues with getting my new Dayton special Tarheel II up to speed on my Big Truck. I am not sure what happened at all. I had it installed and working great on all bands at almost perfect SWR except for 20M which was still under 3 to 1 which I was living with becouse I think its conflicting with other antennas on the cab. I was going to trouble shoot that later.
    Then all of a sudden (well, later in the afternoon) I had issues. I have the mirror mount, and I had it grounded to my door frame which I have had good success with in all other HF Applications in the past. But I think I made a mistake on the mount. I had the ground coming into the "middle" of the mount. (Top side of the ground bolt provided). I believe it was, from bottom to top, bolt head --- mount --- washer --- ground strap --- washer --- lock ring ---- bolt. It was working great, but at a point, when tuning 40, I was able to tune it audiably, but when I went to key it up, the SWR bounced erraticly. Visual inspection showed that the wind from driving had ground down the grounding strap on the mount and it was hanging by threads.
    After replacing it with another crimp, I put it back together, this time with some tape blocking the strap from the mount. But know the antenna was deaf, and I could just BARLY hear an audibale change when in range of a match. It would never dip below inf SWR and never would show any power out. I realized I was suppose to put the ground at the bottom of the mount idealy, so I tried that. There is no change in my problem by doing that. I have it currently from bottom to top, Head --- Ground Strap --- Mount --- Washer --- Washer --- Lock --- Bolt, but I have tried multipule ways moving washers around and such. (Including back on top like Head-Mount-Ground Strap-Washers- Lock - Bolt. I have swapped out coax, taken my meter out of line, and even tried another radio. I am confused. Any ideas?
    Tom
    WC5B
    [/FONT]
  3. Phil1Fla
    Phil1Fla Light Load Member
    298
    53
    May 12, 2008
    Beavercreek, Oregon
    Tom,
    sounds like grounding..Have you tried going to the battery direct?
    I know when I have tuning problems I start with the grounding. and then the problem go away for a while..I'm having problem with my atas 120 But I know it is grounding problem. I had it fixed for about a week. I'm about ready to run a groundstrap from the atas 120 direct to the battery. I always find someplace on the run that the ground has developed a problem. So my advice is grounding.
  4. wc5b
    322
    52
    Nov 5, 2007
    Flint, MI
    After ruleing out all possable issues with the ground itself, including a whole new strap and running it direct, I found the same issue. After a couple of calls to the place I bought it, he suggested maybe it was the plastic washer giving way and shorting out. It looked fine but I swapped it out anyway. Turns out the stub 259 connector plastic peice was defective. Had another sitting around and WALLA! So, after all that, looks like 2 unrelated ground issues at the same time. Now if I could only get some decent band conditions. 3905 sounds like crap tonight. Well.... Hope its the band and not me. Sounded great saturday, and seemed ok monday. But tonight after the fix, I can hardly here anyone. But seems people around me having same conditions.
  5. W5IT
    W5IT Light Load Member
    164
    31
    Aug 31, 2007
    Central, LA
    Something else to remember on the Tarheel is to make sure the little raised strip on the antenna goes into one of the slots in the upper support clamp.
    When that happens the plastic collar is compromised and the antenna grounds to the upper support clamp.
  6. Phil1Fla
    298
    53
    May 12, 2008
    Beavercreek, Oregon
    I forgot that PL259's go bad It has happened to me once or maybe twice. well good luck with your tarheel. Talk to you on HF.
  7. wc5b
    322
    52
    Nov 5, 2007
    Flint, MI
    I would have never thought of that! I think its pointing to the "inside" right now. What slot? I will have to look agian.
  8. EngineDave
    EngineDave Bobtail Member
    Nazareth, PA
    I am considering becoming a driver. If I do I obviously won't have my own rig, I'll be an employee driver. Would there be a problem temp mounting my homebrew screwdriver antenna if I set it up to not scratch/damage anything? Thoughts?
  9. Gadfly
    Gadfly Medium Load Member
    674
    323
    Aug 18, 2006
    A screwdriver antenna does not lend itself well to this kind of multiple mounting setup. Now IF this is going to be a temporary install where you will have the one truck of a specific time, it would probably be OK. BUT!
    .......if you are thinking of some sort of "slipseat" arrangement for HF, I am afraid you are in for a letdown. I'm not saying it CAN'T be done: it is, however, a LOT of trouble and, if the user is not fully experienced in the ins and out of mobile HF, it will be a BIG disappointment. It is, too, very difficult to advise people from afar on this subject since the level of one's expertise will, naturally, vary from none to VERY knowledgeable.
    Assuming a small knowledge level (and I apologize if I accidently "talk down" to you from your standpoint) since I don't know how much you know about HF mobile, one of the most important things about screwdriver antennas is feedpoint impedance since this is VERY important in getting your screwdriver to work AND understanding WHAT is going on with your setup. The FIRST thing I recommend is an MFJ ANTENNA ANALYZER. This device will save you MANY hours of wasted effort in setting up and using your screwdriver since it not only shows SWR, but displays the system impedance in a separate meter. It will readily show if your grounding is off, anything is loose (radical changes in SWR), or "funny" things going on as you drive down the road (such as one "good" reading at a given frequency, and all of a sudden everything is "screwy"---also ONE indication of bad connections or grounds. Also this device can be installed IN the truck and be used to "tune" your screwdriver precisely onto frequency as you go down the road. By installing a quality two-position switch, you can dial in a desired frequency, set the screwdriver to lowest SWR, switch back to the radio, and TALK. It gives you on-the-go, instant data on performance as you drive!
    You should CLEAN your mount periodically down to the stud and get rid of any accumulated crud or rust. This will also cause your antenna to "act" funny after a period of time if you allow rust and corrosion to build up.
    What kind of imedance matching device are you using? This can be a toroid, a coil with a jumper, or wander lead from a turn of the coil to ground (determined by the MFJ meter, or a simple small coil of small diameter wire (transformer wire) wound and inserted at the feedpoint from the mounting stud to ground. A SCREWDRIVER OR OTHER EFFICIENT HF MOBILE ANTENNA WILL NOT WORK WITHOUT IMPEDANCE MATCHING AT THE FEEDPOINT! If it DOES, it means that you have a sloppy, inefficient radiator and poor performance. Yes, there are reasons why this CAN be dont, but trust me, you do NOT want to do this. We won't go into this at this time. That's because it requires a lengthy discourse on complex impedance issues such as feedpoint resistance, coil resistance, and radiation resistance---all values of impedance.
    One recommendation if you are determined to attempt multiple, temporary mountings of a screwdriver. I would use the simple little wire coil: about 21 turns of #22 transformer wire wound around a 1/4" dowel. You would need one for EACH truck you are going to use. And that is only ONE issue!!!:biggrin_2559: You'll need a wired reversing switch (spring-loaded) for EACH truck. Then wire going to the battery from the switch, then to the antenna motor. (Are you SURE you want to try this?????)
    Finally, here's what I think: It's going to be TOO much trouble. I would postpone the screwdriver until I could get into a permanent truck!!! I would simply get me a few hamsticks, and content myself with working 20 thru 10 Meters. That way you can mount a hamstick and operate a band or two, or when stationary and forget about Multiband HF mobile screwdrivers for the time being. Trust me. You MAY know more about HF mobile than I (but I doubt it:biggrin_25525:), but unless you are willing to put in some REALLY imaginative sweat, "slipseating" HF mobile is more trouble than you may realize. Just MHO!
    Good luck!
    Gadfly
  10. EngineDave
    Nazareth, PA
    I am not an expert, but I have been doing HF mobile for a few years. I built 2 mobile antennas and the last one was a screwdriver. I found the plans on the yahoo screwdriver board. I know firsthand that it can be a pain in the neck but I've also had good luck with it. I didn't even use copper wire for the coil, just galvanized aluminum.
    What I've had better luck with was my first HF mobile project. http://www.arrl.org/tis/info/pdf/0004033.pdf
    Only $20 to build (6-20 meters). Two alligator clips to adjust and when you know where to clip you have a resonant antenna. I've worked Europe while driving across NJ in the afternoon. A very easy project and maybe someday I'll try to expand the band capabilities on it.
    Dave N3ZJY
  11. Gadfly
    674
    323
    Aug 18, 2006
    Sounds like a neat project and set-up! I wish you the best with it!
    73
    Gadfly
