tarp help
Discussion in 'Flatbed Trucking Forum' started by wedge542, Jan 30, 2015.
  1. wedge542
    wedge542 Light Load Member
    241
    31
    Aug 13, 2007
    roll tide
    Guys, if you had a 34 deck ft x 8 and only tarped few times a month, deck is 32" off ground, what size tarp would you look for, never haul any wood products at all, most been steel,machines,pallet size parts,tallest yet was 6ft high, im looking for light yet durable as im still learning these tarping tricks, also what about the drings, how far apart, how many rows? thanks
  3. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    wow, 141 lurkers and no flatbedders advise?
  4. Allow Me.
    10,754
    12,522
    May 28, 2009
    Rancho Mirage, Ca.
    Hi Wedge……..Don't feel neglected. I did flatbed for a few yrs and enjoyed it. Lumber tarps have an 8' drop and steel tarps have a 4' drop so your product that's 6' kinda' falls in-between, right ? It sometimes depends on weather or not the product absolutely needs to be completely covered. I suppose you could have tarps custom made with a 6' drop. D-rings will be your personal preference. The companies that make tarps can help you.
  5. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    D- rings are pretty standard at 2ft spacing on tarps. A standard steel tarp is 16x20 ft with 2 rows of D-rings on the longer sides. Do yourself a favor and have the tarp co. sew 2 rows of D-rings on all 4sides, it makes securing the tarps to odd shaped cargo 100xs easier, plus you can turn your tarp any way you wish to tie down a load.
    I pull 48ft flatbed and have 1- lumber tarp 24x32 w/8ft flap- 4rows of D-rings. 1-16x24 steel tarp-2rows D-rings all sides and 1- 16x27 steel tarp w/2 rows D-rings on all sides.
    I rarely use all the tarps but its enough to completely cover a 8x48x8 load. The 27ft steel tarp is my go- to tarp that works on 90% of loads I need to cover.
    You need to figure out a worse case tarping job and outfit your trailer accordingly.
    Typically lighter tarps tear easily and frequently.
  6. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    so,if 16 wide get 2 rows rings per side, how far apart is each row?
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    width = ((max height of load * 2) + 1) + 8
    length = ((34 + (max height of load * 2))
    Example:
    4' high load would require a width of 17' and length of 42'
    8' high load would require a width of 25' and length of 50'
  8. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    thanks skate, 2 rows per side drings?
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I would put D-Rings over the whole tarp separated 16" apart. If you have a really low load you won't have any D-Rings at all to tie it down
  10. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    10-4, what weight should i look for, 13oz-18oz
  11. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I would go for the 18oz. The lighter the weight the easier they tear. If you go with a real light weight and get a hole it's easier for the wind to get a grip and tear it apart. 18oz will not tear.
