I need some technical assistance from those who know regarding trailer air brake systems. Hopefully someone can quickly answer the following questions:
1) Typically do trailers have their own dedicated air reservoir tank to supply the brake units?
2) Is the spring brake valve connected directly to the dedicated air reservoir tank?
3) When the trailer is disconnected from the tractor, do the spring brakes automatically engage and lock the wheels?
Can anyone provide a link to some decent 101 level discussion on trailer air brakes and how they operate during various modes of operation?
Technical question - trailer emergency brake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by patentlawyer, Jul 6, 2011.
1) yes... however initially charged and supplied by the trucks compressor.
2) im not really sure what youre asking... so click here
3) yes, if it has working spring brakes. -
All air brakes are supposed to engage when pressure fails. It is a safety feature. Same on trains.
The air supply actually counteracts a spring in your airbrake cannister and compresses the spring releasing your brakes. When you step on your pedal you are allowing the pressure to bleed off. -
lovesthedrive said: ↑All air brakes are supposed to engage when pressure fails. It is a safety feature. Same on trains.
The air supply actually counteracts a spring in your airbrake cannister and compresses the spring releasing your brakes. When you step on your pedal you are allowing the pressure to bleed off.Click to expand...
Sorry, doesn't work that way. Although the cannister is one piece, the two lines operate two completely separate systems. You're right one line supplies air to a diaphragm and compresses a large spring to release the "parking brake". The other line supplies air at various pressures for brake application.(service brake) -
Thank you all for the input.
Sidepocket, thank you for the link it was very helpful.
Does the service reservoir not continue to supply pressurized air to the spring brake valve, thus keeping the spring brake disengaged (at least temporarily until air pressure within the service reservoir depletes) after the trailer is disconnected from the service/emergency air lines from the tractor? -
When the driver pulls the button on his dash it drains the system. Otherwise the driver will get a nasty surprise when he goes to remove the glad hand connector between the truck and trailer (red and blue air lines).
lovesthedrive,
understood and that makes sense. thank you. nothing beats consulting the experts. -
No, it is not legal by DOT and EU laws. European trailer park valve differs, there are brake buttons on it. Why trailer park brakes are not directly connected to air tank... see answer to q #22) Is the spring brake valve connected directly to the dedicated air reservoir tank?Click to expand...
If supply (red) air line is disconnected trailer park valve dumps air from park spring brakes, but with some delay and wheels lock in some seconds. So if you pull red button in truck trailer park brakes will apply3) When the trailer is disconnected from the tractor, do the spring brakes automatically engage and lock the wheels?Click to expand... -
Ouh, man, it was answer about old style trailers with ABS, newer TEBS, especially TEBS-E have some valves built in TEBS mosulator.
But in the USA simple ABS systems are popular and ABS modulator is combined with accelerating valve. As example - Wabco VCS and VCS-II.
As typical US trailer system http://www.wsafc.org/WSFMA/Shared Documents1/Bendix Air Brake Handbook.pdf
And about Wabco trailer ABS with air diagram http://inform.wabco-auto.com/intl/scripts/intl/pdf/815/00/08/8150100083.pdf
Related Categories
dealership said the truck needs...
gemtrucker posted Mar 6, 2026 at 11:57 PM -
Wabco abs wiring diagram
thillr1 posted Mar 6, 2026 at 8:09 PM -
I’m feeling dumb about transmission
Perchie15 posted Mar 6, 2026 at 7:00 PM -
1995 Peterbilt 379 with DDEC...
blairandgretchen posted Mar 6, 2026 at 8:00 AM -
Looking at some 579's
86scotty posted Mar 5, 2026 at 1:21 PM -
Re gear 3.42 to 3.90 or 4.11?
ODPX15 posted Mar 5, 2026 at 9:19 AM -
isx cm871 jakes
Tegster posted Mar 4, 2026 at 11:14 PM -
Rough ride western star 4900 FA...
Truckerguy917 posted Mar 2, 2026 at 8:05 PM -
CAT C-12 Acceleration...
critterman5 posted Mar 2, 2026 at 5:05 PM -
Can anyone tell me what this...
MattyMatty posted Mar 2, 2026 at 12:11 PM
Loading...
Recent Threads
Head on fatality in KY
supersnackbar posted Mar 7, 2026 at 7:46 AM -
Amazon Jacknifes on Mass Turnpike
JonJon78 posted Mar 6, 2026 at 4:38 PM -
Best Route to Take for this Load!
nextgentrucker posted Mar 6, 2026 at 12:05 PM -
My move to Bruce Oakley (Oakley...
runningman0661 posted Mar 6, 2026 at 11:37 AM -
Fatal Accident Involving...
mjd4277 posted Mar 6, 2026 at 1:32 AM -
FMCSA need 18 Driver To Help...
BrothaTrucka513 posted Mar 5, 2026 at 7:26 PM
Loading...
