Temperature up and down 2016 Cascadia
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by joseph1853, Dec 16, 2021.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Until my truck started having a coolant leak I never really kept an eye on my temperature gauge well not as much as I did after the leak that is. Anyways when going up long hills fully loaded my temp gauge starts to climb a bit and then once at the top of the hill it goes back down. I never really noticed this before, just assumed it stayed at around 220. Anyways is this typical and nothing to be worried about? I mean the fan doesn't even kick on which tells me either the fan temp gauge sensor isn't working or it doesn't sense the temps hot enough to engage it. I usually have the cruise set at 66 or 67 while this is happening. Pic below shows where it gets Freightliners temp gauge.jpg up to mostly. I've seen it go a bit higher than that but not much more. I just had the radiator replaced due to previously mentioned leak also.
    Pamela1990 Thanks this.
  3. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,476
    Mar 18, 2021
    St Malo mb
    Perfectly normal plus the fan only kicks on around 220 iirc
    joseph1853 and Pamela1990 Thank this.
  4. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Oh, ok. I was thinking it was. Appreciate you confirming that.
