The Trucker Chick..
Discussion in 'Ask An Owner Operator' started by AshtonMarie81, Apr 2, 2016.
  1. AshtonMarie81
    AshtonMarie81 Light Load Member
    95
    52
    Apr 2, 2016
    Hey everyone, I been a company driver for 10yrs and I'm looking to get my own truck to run the East coast.. I like older trucks because they got character.. I'm looking at a 98 International 9400 Eagle,, the frame was stretched out with the back half a wrecked 96 379 pete. Running the Petes rear suspension and 5th wheel.. the Engine is a M11 330hp,, and a Super 10 transmission.. the inside is very nice I love the full size bed.. but my question is.. the m11 how reliable are these engines,, it has 900k on it and im planning on having an inframe rebuild done at 1mill... they are asking 8500 for the truck.. its my first time buying my own rig and i cant afford to buy a new fancy truck... I run regional and rack in 2500 to 3000 miles a week..
    Milkman719 and rachi Thank this.
  3. Ruthless
    Ruthless Road Train Member
    9,172
    91,062
    Aug 28, 2010
    The City.
    What kinda work are you planning on doing with it?
    Sounds like not a lot of motor on a less than desirable truck. Not putting you down-saying you ought to be able to get a real good price to get into it.
    brian991219 and darthanubis Thank this.
  4. AshtonMarie81
    95
    52
    Apr 2, 2016
    I run dry van,, tired of my boss not putting me into a good truck.. just because I am a girl i shouldn't be stuck in a dog o matic. 325hp Mercedes, 10spd auto. Mid rise columbia.. I has 10.5 yrs of LTL and OTR exp. Running 10 and 13spds,, so i figure since i has my own broker license, and i applied for my own authority, I'm gonna buy me a decent first time used truck to run northeast regional short hauls... the truck looks good for its age,, but I don't know much about the M11 engine.. I'm familiar with the N14, ISX, cummins and the c15 and 3406e cats.. I cant find any trucks this clean with in my budget, to start with... i figured if i can run it and then have the engine rebuilt i can make a darn good reliable truck... whats your thoughts
  5. TripleSix
    133,262
    Not trying to be negative...
    If you were looking for a pickup truck, and found a half ton with a v6 motor for a good price, I would say buy it. But if you told me that you wanted to use this truck to hotshot and haul cars...I would be less than enthusiastic.
    You run a lot of miles for a regional. They want $8500 for a truck with a small motor that's probably had to struggle. Something tells me that the way you run may make the engine go before you get a year in. Then what do you do? It would work for local. Regional...I don't know. To be honest, I don't know anything about that motor, but I can't see that old of a motor, that small of a motor, standing up for long behind a hard charger.
    For what you're wanting to do, I would recommend the old school 12.7 Detroit 60 series. 430-470 horse.
  6. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    They are VERY rebuildable and VERY reliable, BUT I would limit my gross weight to about 50,000 or less, we have had a bunch of them over the years, IF you rebuild it you can go to about 400 hp, different inj, turbo etc. They will pull more weight, but be #### slow, esp. if you are in the hills/mountains.
    It is a #### good motor if it hasn't been already beat to death and when used WITHIN it's parameters.
    If you are over 50,000 I would hold out for a 12.7 or an N14.
    JMHO
  7. Ruthless
    9,172
    91,062
    Aug 28, 2010
    The City.
    From what I've seen and been witness to: the dry van market really requires some minimizing of costs to be profitable.
    I can't say dollar for dollar if a small motor with (I'd hope) slightly better fuel mileage would be more economical than a larger engine that wouldn't have to work as hard n would hopefully last longer.
    *pat on the back tho for running a 325horse motor. Last time I ran something in that power arena it was a single screw with a 18' box on it. I thought she was a screamer Til I actually ran big power.
    brian991219 Thanks this.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Driving 3,000 miles/week as an independent would be like 3500-4000 as a company driver -- You've got a lot more duties on top of driving, so it is unrealistic to expect the same production from a combination driver/dispatcher/accountant/mechanic.
    Also, there is a hell of a lot more that can go wrong besides needing an inframe. I've spent well over $50k in maintenance/repairs/reconditioning over the first 2 years with my 9400i -- only $14k of that was from the inframe. And I still have the original transmission and one original rear end...
    Radiator
    oil cooler
    charge air cooler
    a/c compressor
    a/c dryer
    a/c condensor
    evap switches
    air compressor
    air dryer
    power steering pump
    steering gearbox
    radiator overflow
    coolant sensor
    boost sensor
    heater core
    all new hoses
    king pins
    suspension bushings
    cab bushings
    shocks
    cab shocks
    exhaust manifold
    turbo-back exhaust
    5th wheel
    injectors
    injector harness
    engine harness
    clutch
    6 new brakes (cam bushings, drums, linings)
    new tires
    brake switch
    clutch switch
    turn signal switch
    and that's just from memory. Running locally, you can probably get by on worn out stuff longer, especially if you know the scales, but my definition of reliable is being able to take 80,000 lbs from Denver to Phoenix (using Wolf Creek Pass) on a holiday weekend, confidently prebooking a follow-up load to Seattle, WA or Miami, FL, and being able to pass a level 1 anywhere along the way...
  9. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    If it were me, I would go for a truck with an N14. What is a must have in the truck? Remember that regardless what people are asking, you can offer anything. The worst they can say is no. Especially right now, if you have cash, you could run away with a deal.
    Are you dead set on your own authority or would you entertain leasing on with a company (big or small)?
  10. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    I would be concerned about the suspension work also. I have repaired more than one stretch job that was done poorly the first time.
  11. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    Id be looking for a Freightliner with a Detroit....pre 2003...cheaper to run, cheaper to maintain....you WILL have to put money into ANY used truck in your first year of operation. Limit your downside on the first one, make some money and in 3 - 5 years, buy whatever you want....
