Thermo King TriPac APU Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cassini, Jul 23, 2018.
  1. Cassini
    Cassini Bobtail Member
    7
    5
    Jul 23, 2018
    Hello, I've searched this whole forum and can't find a solution for my apu. The problem I'm having is, when I turn my apu on, the blower will run for five seconds, turn off and a red triangle will show along with the word "ENG."
    After the blower stops, the apu will crank for two seconds and shut down. I've checked the antifreeze, oil and all of the fuses. Could someone help me out please?
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    If you have a evolution. I will bet my last dollar it's your expansion valve, or evaporator.
  4. Cassini
    7
    5
    Jul 23, 2018
    Yes, it's an Evolution lol. Is there anything I could do until I get to a shop this Friday?
  5. Oldironfan
    5,776
    5,544
    May 22, 2017
  6. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    You need to hook up a latop to read the code.
    Could be anything from low coolant to high or low presure switch.
    And yes you have to be able hook up and read the codes
    You need to get it to a shop.
  7. JonJon78
    JonJon78 Road Train Member
    7,238
    42,990
    Jul 1, 2018
    Sounds like a heat sensor
  8. Oldironfan
    5,776
    5,544
    May 22, 2017
    50/50 odds what I've stated. The new expansion valves are plastic internals. Just to save .02 cents.
  9. Cassini
    7
    5
    Jul 23, 2018
    I just checked my evaporator, and it's full of water at the bottom. What could cause this?
  10. Cassini
    7
    5
    Jul 23, 2018
    Ok. Thank you very much, I'll just idle the truck until I get it fixed.
  11. Oldironfan
    5,776
    5,544
    May 22, 2017
    Probably condensation.
