Thinking about extending my service intervals.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bzinger, Oct 24, 2016.
  1. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    What I have is a 2000 fld classic , 525 n14 red top that I keep around 65 mph or less averaging 6 to 6.5 mpg .
    No idle time other than warm ups .
    I've been doing grease and fuel filter at 10k and drains at 20k .
    Thinking about 12500 grease jobs and 25k drains .
    Any opinions ?
  3. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Im assuming you put 10000 miles on in a month? I would keep greasing it every 10000 at least. Do you need a fuel filter that often? If you really want to extend than go 30 that way its every 3 months for a full service and a grease and level check every month. On my truck if l go 45 days instead of 30 days without greasing it it uses another half of a tube. My comfort level is once a month for greasing.
    bzinger Thanks this.
  4. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Heck I only run about 8k a month...
  5. AModelCat
    164,567
    Grease jobs are about double what I personally would do. Any trucks my dad owned would get greased every week but he was always running off highway too. Grease is cheap and the extra time you spend under the truck could save you a breakdown one day.
    As for engine service, you could probably go longer no problem. Rough math equates running 25k miles at 65 MPH as approx. 380 engine hours. We run most of our engine services on 500 hour intervals with no issues.
  6. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    I used to grease weekly but got tired of the mess , my truck runs very babyed miles and never leaves the road .
  7. AModelCat
    164,567
    You'd probably be fine. My old man kind of looked at like we were going to crawl under the trucks anyways to look them over, may as well pack the grease gun under while we're there.
    passingthru69, Oxbow and bzinger Thank this.
  8. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    This is what oil samples are for. Pull one at 20k and if it looks good extend it out.
    dunchues, bzinger and driverdriver Thank this.
  9. rollin coal
    rollin coal Road Train Member
    13,610
    27,975
    Mar 29, 2008
    TN
    Base your interval on oil consumption. When it burns a gallon add one to it. When it burns a gallon again then it's time to change it.
    lester and bzinger Thank this.
  10. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I watched a few videos of Rawze when he rebuilt his engine. The engine looked really good on the inside, he claims this was bc he changed his oil regularly between 12-15,000 miles. Clean oil is a must he kept repeating.
    You can do whatever you feel you gotta do.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    We did one change a month. That was fine until we approached two changes in a month. DOT got interested in that. As a team we imposed two changes a month. DOT could care less.
    I would not stress over 6.3 or 6.5 in fuel mileage. Im pretty certain one nice half a day breezing east across Kansas once a month at 12 mpg will make up for that.
