Thinking its the Mic
Discussion in 'CB Radio Forum' started by KoolKid, Apr 10, 2016.
  1. KoolKid
    KoolKid Light Load Member
    272
    103
    Jun 15, 2008
    Have a Midland 5001z and have had it for a few years. I had turned the modulations up myself and ran it for a long time that way. always told by CB guys at truck stops sounds loud and clear and they would not mess with it.
    Well, Since coming off the road I have installed it in my pickup truck. Hard wired to the battery, good clean ground, antenna is grounded too. Pick up everything loud and clear.
    However, when I key to talk, I get the red light that it is keyed but needle pulls "down" and wont swing up at all nor do I broadcast.
    betting its the mic but dont see how when I get the red light that I am keying up?
    Thoughts????
  3. Ridgeline
    22,708
    122,476
    I don't get what you mean by the needle pulls down but I am thinking you need to check your antenna first, have your antenna tested by someone with an antenna analyser.
    rabbiporkchop and handlebar Thank this.
  4. KoolKid
    272
    103
    Jun 15, 2008
    well with the needle it could be resting a little to the right, when I key it pulls all the way to the left. The antenna is not old. Think i just need a new radio...lol
  5. Ridgeline
    22,708
    122,476
    NO you need to either get it repaired (burn out the final) or you have a bad antenna system.
    Either way, get someone to look at it who has a dummy load and an antenna analyser.
