how far you have to be to get third lane?
V C Section 22348 Excessive Speed and Designated Lane Use
22348. (a) Not with standing subdivision (b) of Section 22351, a person shall not drive a vehicle upon a highway with a speed limit established pursuant to Section 22349 or 22356 at a speed greater than that speed limit.
(b) A person who drives a vehicle upon a highway at a speed greater than 100 miles per hour is guilty of an infraction punishable, as follows:
(1) Upon a first conviction of a violation of this subdivision, by a fine of not to exceed five hundred dollars ($500). The court may also suspend the privilege of the person to operate a motor vehicle for a period not to exceed 30 days pursuant to Section 13200.5.
(2) Upon a conviction under this subdivision of an offense that occurred within three years of a prior offense resulting in a conviction of an offense under this subdivision, by a fine of not to exceed seven hundred fifty dollars ($750). The persons privilege to operate a motor vehicle shall be suspended by the Department of Motor Vehicles pursuant to subdivision (a) of Section 13355.
(3) Upon a conviction under this subdivision of an offense that occurred within five years of two or more prior offenses resulting in convictions of offenses under this subdivision, by a fine of not to exceed one thousand dollars ($1,000). The persons privilege to operate a motor vehicle shall be suspended by the Department of Motor Vehicles pursuant to subdivision (b) of Section 13355.
(c) A vehicle subject to Section 22406 shall be driven in a lane designated pursuant to Section 21655, or if a lane has not been so designated, in the right-hand lane for traffic or as close as practicable to the right-hand edge or curb. When overtaking and passing another vehicle proceeding in the same direction, the driver shall use either the designated lane, the lane to the immediate left of the right-hand lane, or the right-hand lane for traffic as permitted under this code. If, however, specific lane or lanes have not been designated on a divided highway having four or more clearly marked lanes for traffic in one direction, a vehicle may also be driven in the lane to the immediate left of the right-hand lane, unless otherwise prohibited under this code. This subdivision does not apply to a driver who is preparing for a left- or right-hand turn or who is in the process of entering into or exiting from a highway or to a driver who is required necessarily to drive in a lane other than the right-hand lane to continue on his or her intended route.
Amended Sec. 1, Ch. 300, Stats. 2004. Effective January 1, 2005.
V C Section 22406 Maximum Speed for Designated Vehicles
22406. No person may drive any of the following vehicles on a highway
at a speed in excess of 55 miles per hour:
(a) A motor truck or truck tractor having three or more axles or any motor truck or truck tractor drawing any other vehicle.
(b) A passenger vehicle or bus drawing any other vehicle.
(c) A school bus transporting any school pupil.
(d) A farm labor vehicle when transporting passengers.
(e) A vehicle transporting explosives.
(f) A trailer bus, as defined in Section 636.
Amended Sec. 22, Ch. 787, Stats. 2000. Effective January 1 2001.
Third lane Code 22406 or 22348
Discussion in 'Trucking Industry Regulations' started by moujick, Feb 25, 2013.
" A vehicle subject to Section 22406 shall be driven in a lane designated pursuant to Section 21655, or if a lane has not been so designated, in the right-hand lane for traffic or as close as practicable to the right-hand edge or curb. When overtaking and passing another vehicle proceeding in the same direction, the driver shall use either the designated lane, the lane to the immediate left of the right-hand lane, or the right-hand lane for traffic as permitted under this code. If, however, specific lane or lanes have not been designated on a divided highway having four or more clearly marked lanes for traffic in one direction, a vehicle may also be driven in the lane to the immediate left of the right-hand lane, unless otherwise prohibited under this code."
2 lanes in your direction: use right lane except to pass (unless sign says use left lane)
3 lanes in your direction: use right lane except to pass (unless sign says other lanes permitted)
4 or more lanes in your direction: use right or lane immediately to left of right lane (unless otherwise instructed by signage) -
Is there a point in all this somewhere?
the question is "how far you have to be to get third lane"? you didn't answer my question
its no point if you are not driving in CA
If your going to speed it's better to do 100+ than 15 over.
if the lane isnt designated & you are neither merging nor passing -- 1" could get you a ticket.
