Throwing belts
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jasonar15, Aug 21, 2018.
  1. Jasonar15
    Jasonar15 Medium Load Member
    669
    519
    Aug 6, 2017
    12.7 Detroit throwing belts. The 3 that go from crank to fan. Will fan hub or fan clutch be the problem if alignment is good?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i am not certain a fan clutch, as much as i'd think about the crank pulley (or harmonic balancer), since it is pressed into place surrounded by rubber to dampen the vibrations.
    misalignment is an issue of maybe a device connected to the crank that was not installed correctly, or may be loose, or have a broken mounting bolt.
    Oldironfan Thanks this.
  4. wore out
    wore out Numbered Classic
    17,305
    214,677
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Look and see if the belt grooves are worn. If the belts are trying to roll when they are tightened that's most likely it.
  5. Jasonar15
    669
    519
    Aug 6, 2017
    Brand new belts.
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Im going out on a limb and guessing this is a ddec 3, or early 4 engine, and harmonic balancer is original? Replace it, with a new 14 liter balancer. And has the kysor fan clutch been adjusted lately?
  7. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    He's saying your pulleys are worn. When the new belt v does not match the worn pulley there is not enough contact area for the belt to bite, grip the pulley. Causing heat and the belt fails or rolls.
    Also common with v belt pulleys is the belt will actually bottom out in the bottom of the pulley due to excess wear. Once it does no grip, just slip. New belts will fix it briefly then it's the same old story.
    wore out, Justrucking2 and Oldironfan Thank this.
  8. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Damper, or harmonic balancers do wear out, Cummins recommends replacing every 500,000 miles. I would imagine Detroit has similar numbers. There is a viscous fluid in the damper, with age it hardens, then bad things happen. I’ve seen them actually blow apart, it can be an expensive repair.
  9. Jasonar15
    669
    519
    Aug 6, 2017
    2000 model. Just put belts back on and the top of V does not sit all the way down in the pulley. When I started the front 2 flipped over and back one closest to motor was fine. Has 650k miles and neither harmonic balancer or fan pulleys have been replaced. No clutch adjustment either to the best of my knowledge
  10. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Best to start replacing, I replaced all of mine, including damper at around the 800,000 mile mark. No more belt issues.
  11. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Maybe someone put the wrong belts on it at one time??
    If there too wide they wont fit in the pulleys properly. They will sit too high.
    I find it hard to believe if belts are the right ones and adjusted correctly that they would ever pop out. Worn pulleys will only make it slip but never pop off. My guess they are the wrong width belts
