Time for Hammer's Winter Driving Tips
Discussion in 'Experienced Truckers' Advice' started by Hammer166, Dec 11, 2021.
  1. Hammer166
    7,601
    27,764
    Aug 18, 2007
    ~8600+' and loving it!
    I've done this several times, but it's been a bit and it is that time of year.
    Here's one of the older threads, and I can't promise I won't repeat myself!
    Winter Driving w/o the platitudes.
    This won't be as long as I'm on the phone instead of laptop.
    Probably the most important thing to remember is that your tires traction limits in one direction effects the limits in the others. So if you're using all your traction to accelerate, there's not any traction left for lateral stability or cornering. Or vice versa. That's something we all know from the seat of our pants, even if we don't understand it in exactly those terms. We all know how a hard accelerating or breaking vehicle feels a bit squirrel, and that is why. You've used up most of the tires available traction.
    So if you remember this, you can use it to your advantage, and limit what you ask of your tires in the directions you don't need at the moment. So minimal accel/decel when you need to corner, and as little turning as possible when it's time to stop or start.
    Which reminds me of another critical point, neutral throttle. That's not zero throttle, that's the point at which engine putting zero input into the tires. And that's important to know because the most stable state of a truck and trailer is at or just slightly above neutral throttle. At that power setting, there is either no load or a very slight pull at the kingpin. You'll likely still be decelerating at that setting. But this eliminates the truck or trailer from introducing forces into the other that would require traction to overcome. It's a much more stable condition than coasting, where the trailer is pushing the truck with the kingpin. As this guy found out :
    And I think I'll leave there for now... Pizza and adult refreshments are calling!
    Banker, LoboSolo, Oxbow and 14 others Thank this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,974
    19,013
    Nov 1, 2010
    Burnsville, MN
    You do seem to like using Swift as an example.
    But yet, with your initial post, those examples do not even apply.
    That first driver was not applying forces to any great degree in any direction, the diver hit some ice.
    The same goes for the blue little truck.
    And in that case it does not matter what you are doing, you are simply sliding and out of control.
    The remainder of the video is basically worthless.
    Your advice is good and welcome for driving in low traction conditions, but if you are going to add a video to demonstrate it you should make sure it is the correct one.
    ncmickey Thanks this.
  4. Hammer166
    7,601
    27,764
    Aug 18, 2007
    A bit touchy, are we? You happen to notice I didn't mention the name on the truck, because it didn't matter. I believe the search terms I used were "truck jackknifes on icy bridge." This was the video I was hoping to find, but I couldn't have told you the name on the truck. I only knew it as a prime example of what not to do.
    Watch that video again. (Sorry, only the first clip of the video. My bad!) You can see the headlights dip as the driver jumped off the throttle. It's pretty #### obvious that that action caused the drives to start sliding once he hit the icy bridge. By going to no throttle he demanded more traction than the drives could provide, causing that slide (you can plainly see the truck jump when the drives try to regain traction once he hits wet pavement again.) Had he gone to neutral throttle he would have just coasted across there with no issues. And quite frankly, while I didn't intend for the blue pickup to be part of this discussion, had he followed my advice, he'd have coasted right across there without spinning as he did. So I actually [GASP] DID pick a video that demonstrated exactly what I needed it to.
    This is one of my biggest pet peeves with what comes out of safety departments across this industry. "SLOW DOWN!" is their answer for every situation, when there are very definitely situations where slowing is not the correct answer. Now one could argue that driver should have been going slower, but he'd have been just as far out of shape had he been traveling half that speed and had the same response.
    Moosetek13, Oxbow, Vic Firth and 5 others Thank this.
  5. jeffman164
    jeffman164 Medium Load Member
    630
    587
    Dec 4, 2012
    Interesting. Never knew that about neutral throttle.
    Hammer166 Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,310
    10,231
    Jan 30, 2012
    Charlotte, N.Carolina
    Hammer166, your absolutely correct, thought it was "common sense".
    guess I thought it was long ago, when sense was common.
    been coasting over icy bridges for over 50 yrs. lol
    learned that the first winter with my new drivers license.
    Oxbow, Hammer166 and bzinger Thank this.
  7. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Doing donuts on a frozen lake should be mandatory for getting a driver's license.
    Waterman_99, Numb, Oxbow and 2 others Thank this.
  8. Hammer166
    7,601
    27,764
    Aug 18, 2007
    It's all about maximizing your available traction. If you are not using any to accelerate or decelerate, every little bit you have can be used to maintain the trucks path. And on something with a near zero coefficient of friction like wet ice, it could well be the difference between going on down the road and exploring the ditch.
    Waterman_99, Oxbow and bzinger Thank this.
  9. Moosetek13
    14,974
    19,013
    Nov 1, 2010
    Burnsville, MN
    OK, fine.
    I can't disagree with that.
    Sorry I was 'touchy'.
    I've had things like that happen even in wet weather.
    On a curve in the wet and the drives start to slip out from under you. And with traffic in both lanes.
    A very, very light touch on the throttle, up and down, with steering correctly got me out of it.
    The first rule is the basic rule... Don't PANIC!!!
    I learned that from Hitchhikers Guide...
    No sudden movements with throttle or brakes or steering.
    Everything has to be a very light touch, or it goes south in a big way very fast.
