Timpte Axle Oil Checking
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by markk, Nov 24, 2022.
  1. markk
    markk Medium Load Member
    566
    197
    Nov 14, 2011
    Anyone have a trick for checking oil in the axle with auto inflation caps that can't be seen through ?
    Mine have turned a mucky brown color on one and just black on the rest. I've tried a very bright light , even shining into thé fill hole.
    I really don't want to take the glass off unless have to. I suspect it would not seal back up and no one open to buy a seal from
  3. Big Road Skateboard
    7,093
    40,235
    May 2, 2021
  4. markk
    566
    197
    Nov 14, 2011
    No. They leak when a seal goes bad. They have a sight glass and a plug on top of the cap to unscrew . The cap sight glass is removable. A bunch of little screws . Can't see through the things and they are only 2 years old. 2021 timpte. Mine are not leaking but that one with a tan color in it worked me.
    Looks like this but different brand . Notice the fill plug behind that air line.
    Hendrickson - TIREMAAX, TIREMAAX PRO-LB, TIREMAAX PRO TIREMAAX CP Tire Pressure Control System
