Tire Pressure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Waterman1000, Sep 30, 2010.
  1. Waterman1000
    Waterman1000 Light Load Member
    50
    Jan 18, 2009
    Ok,
    I need to conferm a argument between the tire shop and my mech.. The tire shop guy told me to run my tires up to the max psi on the caseings. The mech says to run aprox., 10psi under max on the caseings. Whats your guys/gals opinion.
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    I worked for a trucking company, a while back and the tire man would have the drive tires at the max preasure, he would walk around and check the depth of the tread across the face. If it is overinflated, it will be worn more in the middle, if it is under inflated it will be worn more on the edges.
    I would inflate to the max on the drivers and steers, then with a depth gauge modify the fronts by the tire wear.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I always went 5 over p.s.i. 110 on all tires except in exreme hot weather. if you put 105 like most say on sidewall after a few cold nights, you will find pressure will drop. 110 & I never had a wear problem.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I have been doing alignments for years. Almost all the time I see irregular wear, river wear, cupping, I also find under inflated tires. I always recommend the rating that is one the sidewall of the tire. The guys with no tire wear issues keep their pressures up to the rated limit. No question here!
    Les2 Thanks this.
  6. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    IMO, run the correct psi for the weight the tire carries and speed operated at. all tire mfgs publish inflation tables. I use Michelins tables and get great wear. if you dont check psi at least once a week your probably better off with max psi. kicking or thumping tire dosent count.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Idea is 105 and 95 on steers for wear. But with todays high cost of fuel it's cost effective to run 110 all the way around. That's what our college grad bowtie desk jockey fuelman expert tells us. :)
  8. Waterman1000
    50
    Jan 18, 2009
    Thanks all for the replys.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    thats why I run 100 all around. just wait til the winter gets here. you can have 105 but when the temp dips to 15 20 degrees you'll check & you will find at least most of your former 105 psi will be 95 or so psi
  10. Trouble65
    Trouble65 Medium Load Member
    621
    147
    Jan 11, 2009
    Ontario Canada
    Just go by what is stamped on the sidewall of the tire. If you see to much wear in the middle of the tire bring the pressure down by 5psi. If outsides are wearing too much add more pressure.
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I try to inflate until they stop bulging but got scared at 135.
