Tire problem
Discussion in 'Experienced Truckers' Advice' started by Newbieboy, Sep 11, 2019.
  1. Newbieboy
    Newbieboy Light Load Member
    91
    25
    Apr 3, 2019
    My both steers become like this in 2 days. What could be the problem?
    Im shutdown at TA to check allignment .
    Please advise
    Lepton1 Thanks this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    You are turning too short and hitting the spring, frame or something. I (just my opinion) sure would not let TA touch my alignment.
    KB3MMX, PE_T, x1Heavy and 2 others Thank this.
  4. Long FLD
    Long FLD Road Train Member
    12,735
    53,193
    Mar 4, 2015
    Severe toe out?
    Edit: didn’t see the pic with the slice in it. I second what @starmac said. Looks like You’re getting into your spring or hanger or something.
    PE_T Thanks this.
  5. Newbieboy
    91
    25
    Apr 3, 2019
    You guys think its not allignment issue?
  6. Newbieboy
    91
    25
    Apr 3, 2019
    TA is all set to put new tire but i need to find problem before putting new tires.
  7. AModelCat
    163,835
    I gotta go with the wheel cut being set too sharp and contacting something on the frame or suspension.
    PE_T and Lepton1 Thank this.
  8. Long FLD
    12,735
    53,193
    Mar 4, 2015
    If it is I wouldn’t trust T/A to work on it. Find an alignment shop if it is.
    How does it handle going down the road?
    mp4694330 Thanks this.
  9. Newbieboy
    91
    25
    Apr 3, 2019
    Its shakes lil bit at 70 i believe it’s normal.
  10. Newbieboy
    91
    25
    Apr 3, 2019
    M sure its not kingpin. It’s something else.
  11. Diesel Dave
    9,530
    31,562
    Jan 20, 2010
    Hesperia, Ca.
    I agree also that it’s hitting something when you turn sharp. Look around and see if you have any marks, Frame, spring, and or any accessories mounted on the frame.
    But I wouldn’t leave out the toe being to out either.
    Goodysnap, PE_T, jammer910Z and 3 others Thank this.
  12. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have seen a lot of wear from some serious bad tow ins or outs, but never seen it rip chunks out. I am betting there is some shiny metal there somewhere.
    Lepton1, Newbieboy and Diesel Dave Thank this.
