Tire Question.
Discussion in 'Freightliner Forum' started by Eugene Onegin, Sep 29, 2011.
  1. Eugene Onegin
    Eugene Onegin Bobtail Member
    Berkeley Springs,WV
    Whats going on is this ,my nephew has a 2011 Freight Liner Cascadia with 105000 miles on it and he is concerned about his front tires ,the driver's side tire is wearing out on the inside and the passenger's side is wearing out on the outside ,he says the the truck has had two alignments by the same shop ,What do you think is going on ?
  3. The_Truckr
    The_Truckr Bobtail Member
    7
    Sep 30, 2011
    Artesia,CA
    Do u know if the truck has been in any accidents?
  4. Eugene Onegin
    Berkeley Springs,WV
    The_truckr No accidents,it's a 2011 .
  5. 3rd Gen Driver
    3rd Gen Driver Light Load Member
    134
    25
    Jun 6, 2010
    SC
    Ck king pins and alignment @ a different shop
    When they jack the truck up they'll pull up on the rim with a big crow bar
    If the top of the tire move more than a 1/4" replace the king pins
    But you shouldn't be having king pin problems w/ 100k mi
    Worth checking though
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Go to a different shop. The tandems are most likely out of alignment. The camber could be out on both sides of the steer, but I would bet on the rears. If you look at the drive tires, you should see alternating inside and outside edge wear on those if it is the rear axles.
    heyns57 Thanks this.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    dont forget to check the alinment on the trailer(if he pulls the same one all the time). it can contribute to it also.
  8. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    I talked to an alignment guy awhile back he mentioned a company the he worked for was having the same type of problem. The fix was simple he adjusted the steering stops so the wheels would not turn so far. The reason being on the those trucks they tend to "lay" the wheels over and in a tight turning manuver it rakes the edges off. So if you give up a little turning ability you gain in tire wear.
  9. Eugene Onegin
    Berkeley Springs,WV
    OK Guys ,Thanks ,I'll give him the news .
  10. red semi
    red semi Bobtail Member
    28
    4
    Nov 13, 2012
    new york
    check spacer blocks under springs. had same issue ,right spacer higher than left.
  11. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Imo, wrong drivs axels algmen, but Toe-in is ok ore bent frame, loose rear mountings, spring bolts.... the reason to inspect all this stuff
    Cowpie1 Thanks this.
