Tire Question
Discussion in 'Experienced Truckers' Advice' started by Peterman88, Jan 23, 2018.
  1. Peterman88
    Peterman88 Light Load Member
    69
    42
    Nov 29, 2017
    Arizona
    hello everyone got another tire question. I’m buying a set of 295/80/22.5 tires Friday currently my truck has 275/80/22.5 the inside of the stamp on the rim say 8.5 . Will the wider tires be a problem??
  3. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
  4. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    But why?
    Cheaper,?
    Lol
  5. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
  6. Peterman88
    69
    42
    Nov 29, 2017
    Arizona
    Well I’m getting 4 used tires from a guy online so definitely there cheaper. And I didn’t don’t want to buy them and then find out there to wide. Thank you for the input
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    Your rim width matter.
    You can put somewhat larger to a maximum permissible size. It's not always wise to do so.
    When I purchased tires on my vehicles, I check the rim size against the factory permissible maximum for that rim width. Then carefully pick a size one step below the widest.
    Steel Dragon Thanks this.
  8. Peterman88
    69
    42
    Nov 29, 2017
    Arizona
  9. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
  10. Peterman88
    69
    42
    Nov 29, 2017
    Arizona
    Smaller and skinnier?
  11. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    Where are 4 mismatched tires going?:biggrin_25521:
