tire rotation
Discussion in 'Ask An Owner Operator' started by rank, Jul 10, 2025.
  1. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    what's everyone's thoughts on how to rotate tires. I've got some tires that are wearing unevenly. Some tire guys say once a tire was rotated in one direction you should not change it. Other tire guys say it doesn't matter. I don't want to dismount and mount for no reason
  3. Long FLD
    Long FLD Road Train Member
    12,840
    53,732
    Mar 4, 2015
    I did my drives in an X so that they did rotate the opposite direction. Steers I just did side to side, never broke them down to keep them spinning the same direction.
  4. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Oxbow and rank Thank this.
  5. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    When I rotate drives, I put them back on so they do rotate opposite direction.
    Bean Jr., Oxbow and rank Thank this.
  6. Diesel Dave
    9,635
    32,555
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on the “X”.
    Oxbow, Deere hunter and rank Thank this.
  7. abyliks
    abyliks Road Train Member
    4,108
    9,656
    May 2, 2010
    ludlow MA
    Fronts go straight back rears get cross to the front
    Oxbow Thanks this.
  8. Short Fuse EOD
    2,791
    8,760
    Jul 29, 2015
    Midwest
    Never found a need to rotate tires. They all wear pretty much even. BFG/Michlin/Continental/ mold cure retreads from formerly Olson tire now Bauerbilt on trailers
  9. MAMservices
    MAMservices Medium Load Member
    596
    4,384
    Aug 9, 2021
    My understanding is that keeping the same rotational direction was designed out of tires shortly after radial tires came on the scene. The bias ply tires would become “biased” to a rotation account of the design of the polyester and fiber layers, in time. When direction changed, they were very prone to delaminating and flying apart.
  10. Sumtinlidat
    Sumtinlidat Light Load Member
    138
    425
    Dec 17, 2017
    Las Vegas Nevada
    I run Hancook DMO4’s on my truck and rotate the drives in an X pattern every 20k. I’m in the dirt most of my days so I spin and slip more than most. I’ll average 70-80k miles per set till they need to be swapped out. If I don’t rotate em I’ll wear the drives out too quick to where I can’t keep up with wearing em all down the same and I hate changing only 4.
    Steers are continentals and get swapped side to side every oil change. 10-12k when I get the time to do em
  11. AModelCat
    164,540
    Don't they rotate every time you drive?
    wichris and FullMetalJacket Thank this.
