Tire straps
Discussion in 'Flatbed Trucking Forum' started by PSM379, Nov 5, 2024.
  1. PSM379
    PSM379 Heavy Load Member
    946
    3,901
    Apr 19, 2019
    Occasionally I will haul a pick up truck, ambulance, service truck, mini bus etc on my step deck. At times it is a hassle to get chains anywhere on them, searching regs I can’t find the law I thought was in place any wheeled vehicle over 10,000lbs needs to be chained. Was I imagining this, I do see car haulers with bigger vehicles and ambulances tire strapped at times. Is this legal, is there an actual regulation on this. By no means trying to come off stupid, in my searches can’t find info. Because it would definitely be easier to tire strap some bigger vehicles. I’m not talking a semi, or backhoes, I’m talking service trucks, ambulance, cargo vans etc.
  3. Razororange
    Razororange Road Train Member
    2,710
    25,778
    Dec 20, 2011
    Milwaukee, WI
    The only law is the requirement for 4 corner securement for vehicles over 10,000 lbs. Nothing in the laws specify chains or straps. So you would be legal to tie down a 10K+ vehicle with 4 wheel straps.
    Another option would be to look at what towing guys use for securing vehicles. it might be worth the investment to pick up some large J hooks or cluster sets if vehicles are a common thing you haul.
    A J hook like this with a few chain links on the end that you could hook a binder or grab hook on your chains to might give you more options.
    cke, D.Tibbitt and PSM379 Thank this.
  4. Banker
    Banker Road Train Member
    4,504
    14,532
    Aug 19, 2012
    The straps I am familiar with on a traditional carhauler are 3,335 WLL and have the Working Load Limit printed on them. Regardless of what you were hauling the WLL has to exceed one half the weight of the freight. The largest units I have experience with are 5500 cab and chassis and generally are in the 8,000 lbs range. With a bed of some type they would still be below the 26,680 lbs that 4 straps could legally secure. If you are hauling something crazy heavy chains would be a good idea anyway in my opinion. IMG_3223.jpeg IMG_0309.png
  5. PSM379
    946
    3,901
    Apr 19, 2019
    I do use chains 95% of the time. Only thing I’d love to use the tire straps for are ambulances and some other low clearance stuff chains would be a hassle. That must be what I was thinking the 4 corners over 10,000lbs. Thank you for the info on this. Been at it a while, just wanted to make sure I was correct before I did something.
    cke, Oxbow, D.Tibbitt and 1 other person Thank this.
  6. Banker
    4,504
    14,532
    Aug 19, 2012
    You would be legal securing with 4 wheel straps on any ambulance I have seen mounted on a traditional truck chassis.
    cke, Oxbow, PSM379 and 1 other person Thank this.
  7. Albertaflatbed
    Albertaflatbed Medium Load Member
    408
    1,191
    Nov 20, 2022
    Nisku, AB
    I use straps when I haul vehicles on our tiltdeck. I use regular 2" ratchet straps around each tire.
    If I am moving larger vehicles such as 2 ton cube vans / busses / semis then I go to chains.
    Most light duty vehicles are just too difficult to chain due to low clearance and hoses/wires run where you want to out the chains. Straps work fine, meet legal requirements and especially on things like ambulances are alot easier.
    cke, PSM379 and D.Tibbitt Thank this.
  8. D.Tibbitt
    156,937
    You could always make a tire lasso out of a 2in strap and ratchet. Makes it easier hauling cars on a deck
  9. SomeCanadian
    SomeCanadian Light Load Member
    166
    481
    Nov 11, 2021
    For what you’re trying to achieve they make a strap that joins your ratchet to make it a “tire strap”. They look like an infinity symbol with a long straight part in the middle. Pass ratchet through one eye and around the back of the tire, then through the other eye. If I was going back to tire straps I would spend the money on full basket straps.
    If you really wanted to start a fight with a dot, rim sling. If one can pick up a whole unit it must be good enough to hold it down.
    cke, Albertaflatbed and D.Tibbitt Thank this.
  10. PSM379
    946
    3,901
    Apr 19, 2019
    10-4 I’ve done that a few times hauling the family vehicle on my step deck. Don’t work bad at all.
    cke, D.Tibbitt and Albertaflatbed Thank this.
  11. The N.P.R.y guy
    The N.P.R.y guy Light Load Member
    213
    1,100
    May 4, 2024
    To me I guess it depends on the vehicle. I haul kei trucks sometimes (well recently very often) I don't recommend chains on those. I haven't heard about anything over 10,000 lbs chains or bust rule. And you do have the occasional driver who will strap down a dozer with ordinary straps. Don't recommend that either. As long as you have your load tied down in the right places and it looks good to the dot, they'll leave you alone.
    cke and Albertaflatbed Thank this.
