Tire Thumping
Discussion in 'Trucks [ Eighteen Wheelers ]' started by flightwatch, Nov 21, 2011.
  1. flightwatch
    flightwatch Road Train Member
    1,249
    1,250
    Jun 22, 2011
    Somewhere in Texas
    I was at a truckstop this morning with my tire guage in one hand and the gladhand air hose in the other when a tanker driver got out with his tire thumper. After giving me one of those looks, he proceeded to thump his tires. In the time it took me to put 10psi in one tire, he had thumped all 18 of his.
    My question is why do some of you all thump your tires? To check if they're flat? Because I can do that with my tire gauge. Is it laziness? Maybe you think it looks cool. Honestly, I am seeing 0 logic in thumping your tires. DOT states that any tire with below 80psi is considered flat. How can you tell that it has that much air by taping it with a wooden stick?
    I am not trying to be condescending at all and I m certainly not trolling. I am trying to figure out ya'lls logic.
  3. Tardis
    Tardis Light Load Member
    211
    118
    Nov 6, 2011
    banned or retired
    I thump with a small sledge hammer because it gives more predictable results. That said, you can tell if a tire is low by thumping. I thump everytime I stop. I wouldn't check as often if I had to use a gauge.
    heyns57 and crb Thank this.
  4. georgeandson
    georgeandson Heavy Load Member
    890
    647
    Feb 18, 2011
    1 mile down the road.
    after you tump so many tires you can tell pretty well which is low and which is not. i know its weird sounding but you can.
    some guys will know real close if its the same truck they been driving and has run the same type of tires for ever.
    crb Thanks this.
  5. blackpipes
    blackpipes Light Load Member
    61
    18
    May 4, 2010
    king ferry,ny
    Its not done to check the exact pressure in s tire. Its just a quick check to make sure u dont have a tire thats real soft which would need further inspection. U still need a guage to get the pressure rite. I just prefer to do that in my shop with all the proper tools and time and if I get dirty its ok. People think that guys thumping tires are duin it as if they can tell the pressure by the thump. Thats impossible and I doubt anybody would say they can. Its just a quick way to tell if u have a problem. Besides at least that guy checked at all. Too many of these steering wheel holders wouldnt know the tire from the mudflap and dont check either!
  6. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Pull a 6 or 7 axle trailer and then tell me your gonna be checking 34-38 tires using this method on a regular basis. Tandem yeah sure you can do it in adequate time but not gonna happen with the extra tires
  7. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    I always use a gauage.
    Use to pull triples...30 tires. Always used a guage, every day.
    Most drivers don't check pressure. Most drivers don't even thump!
    That's why there's so many gators on the road!
  8. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Thump every time you get out and check with gauge regularly. just a quick check is all it is
    Tazz Thanks this.
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    i thump my tires 2 or 3 times a day i check air pressure when i change my oil .
  10. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    From years of thumpin tires and from the sound they make, thats how.
    I run 120psi in my steers and 130 drives and trailer and when a tire is at 100psi its sounds flat to me. Also at the high psi I can take my hand and pat the tire and if it dont sound right I get the gauge out.
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    First off you check tires when cold not on the road, when at a brake check. Thumping tires, gives you an idea of the pressure. I use an infered thermometer also check the tire temperature as well as the hub and the brake drum if it is hot. Heat is an indication of a problem. Especially if all but one is cool.
    You can add pressure to a hot tire, but on the road you get a maximum of about 100 lbs with any length of hose unless you are there for a long time.
    There is a brake check near my location and it is rare to see truckers do a walk around and inspection let alone check pressures.
