Tire wear question, shoulder wear on steer tires.
Discussion in 'Ask An Owner Operator' started by MTMAUS, Jan 16, 2026.
  1. MTMAUS
    MTMAUS Light Load Member
    258
    217
    Sep 28, 2019
    What causes wear on both shoulders of the tires that isn't pressure or alignment related?
    Got wear on both shoulders of both steer tires, have done wheel alignments and kept psi at 120 on multiple sets of tires.
    Was getting solid 100 - 140 thousand miles per set with tread left before putting them on a trailer, but now it's slowly got worse with each set and gone down to about 50 thousand miles before getting bad shoulder wear, but with lots of tread left.
    I think it must be in the steering box/linkage or something, everytime I check psi I am at 120 and the last few alignments have been done but nothing majorly out of whack and everything was aligned when a new set of tires put on.
    Truck has 1.1million miles with little done to the steering components. The steering does feel sloppy compared to when I hop in another truck, but I am pretty used to mine, so don't notice it I reckon.
    Truck is a Freightliner with dd15
    Any ideas? Thanks
  3. MTMAUS
    258
    217
    Sep 28, 2019
    Forgot to mention, Kingpins and tie rod ends checked, no movement in the hub/wheel etc when checked with both a bar and by the alignment guys
    Rideandrepair Thanks this.
  4. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
  5. D.Tibbitt
    157,089
  6. MTMAUS
    258
    217
    Sep 28, 2019
    Thanks, it's pretty much exact the same as page 112 , but on both inside and outside of the tires. Your document says to do nothing lol, maybe it's not as bad as I thought.
  7. 201
    201 Road Train Member
    12,773
    26,282
    Apr 16, 2014
    high plains colorado
    Typically, wear on both edges but not the center, would indicate underinflation. I never ran that much pressure in a steer, maybe 100 tops for 14 ply, I read 16 ply can go 120. I can say without reservation, over the years, I've ran just about every steer tire made, and no 2 wore alike. I never got 100K out of a steer tire, but always had jobs with a lot of turning, I'd try a different pressure gauge, no 2 of those were ever the same either. I think it's just the crap tires of today.
    07shaker Thanks this.
  8. abyliks
    abyliks Road Train Member
    4,113
    9,675
    May 2, 2010
    ludlow MA
    What brand tires? I would probably try a different alignment shop,
    I run 130 psi in mine
  9. Long FLD
    Long FLD Road Train Member
    12,861
    53,828
    Mar 4, 2015
    How are the bushings on your rear suspension?
    Big Road Skateboard Thanks this.
  10. Big Road Skateboard
    7,093
    40,235
    May 2, 2021
    Steering box, drag link, and shaft will affect drivability, but won't cause wear like you're describing, and has no effect on alignment.
    What area are you running, and what tires? What style of tire?
    A pic would help.
  11. SmallPackage
    5,777
    18,552
    Dec 20, 2019
    Marion Texas
    On straight axles guarantee tires just wear like that. Manufacturers have tried to combat that with decoupler grooves on the tread edges. They help in many cases but not a guarantee. The first radial truck tires were the Michelin XZA without the decoupler groove. Them things would get nasty wear. Goodyear saw this in the early 80’s and came out with the G259 with the groove. It did much better. Michelin soon came out with the XZA2 with the groove and took the lead. Turning radius also plays a hugepart in that shoulder wear. Axle kingpin angles on Older trucks kept the tires more upright on the tread patch during turns. The newer angles for quicker tighter turns lay the tires down lower on the sidewalls and pinch and scrubb the edges of the tread badly. The tighter the turns the faster the wear on steers.
    1999 C12, wore out, Lonesome and 2 others Thank this.
