too hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by johnnyquick, Aug 5, 2009.
  1. johnnyquick
    johnnyquick Bobtail Member
    hamilton ontario canada
    i have a freightliner classic with an n14 and lately my cooling fan comes on at 210 and shuts off at 205.is there a fan timer on freighliners?
    my last truck was a ford ltl9000 with the n14 and it had a 3 minute fan timer that i had to replace a couple of times in 6 years,but i can't find one in my freightliner.HELP!!!!!!!!!!
  3. wtm
    wtm Light Load Member
    118
    18
    May 11, 2009
    south
    Thats about the same as my fan on my n14 runs. Mine wont ever get that hot unless its pulling pretty hard or in this summer weather just pulling decent.
  4. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
  5. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    If your engine is maintaining 210 and not going higher I wouldn't freak-out.Ask your EPA why engines run hotter than previous years.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    If it is running hotter than what it used to, you probably only need the rad power-washed. You may have a layer of dirt, or bugs, partially blocking air flow. Usually we have to partially remove the air-to-air cooler to get in there to clean out the rad. Have a look.
  7. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,605
    45,928
    Jul 23, 2007
    Midwest
    Big Duker Thanks this.
  8. jride
    jride Light Load Member
    91
    Mar 22, 2009
    in my living room.
    heads have no cracks rite..my guess tho would be its a combo of things.
  9. jride
    91
    Mar 22, 2009
    in my living room.
    if the engine has been rebuilt, its gonna cause it to run warmer now than before, because of the decrease in the cylinder walls thickness also.
