Tool for chaining
Discussion in 'Oilfield Trucking Forum' started by Rich W, Oct 8, 2019.
  1. Rich W
    Rich W Bobtail Member
    5
    Aug 15, 2019
    Ok winter is coming which means a lot of chaining. So, what's the best tool to hook the chain rails so you can 'stretch' them far enough to hook? The T handle tool works a bit better than 'tire iron' type tool but there's got to be a better way.
  3. speedyk
    speedyk Road Train Member
    1,837
    2,471
    Apr 8, 2015
    Tool? For chaining?
  4. Rich W
    5
    Aug 15, 2019
    As I said a tool better than these for getting the chains hooked.
  5. okiedokie
    okiedokie Road Train Member
    13,684
    107,861
    Jun 13, 2011
    PNWET
    Whats the problem? Not enough leverage.
    Tx Countryboy Thanks this.
  6. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    You can try using sleeves on the T handle bars to extend them some. Odds are with too much leverage you will just snap the tip off in the chain and face plant into to rim.
    Keep them tight while wrapping and don't have brand new tires
    speedyk Thanks this.
  7. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    They make mini/small lever binders, that might work.
    But, I think your chains are too small if they are that hard to hook together.
  8. skellr
    8,735
    12,187
    Jul 17, 2011
    I bought a "super chain tool" from Jubitz a while ago.
    Awesome leverage for tightening the cams but it was around $50...
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    LOL, I chain sometimes multiple times a day, and have never tried to stretch a chain yet.
    I hate and will not even carry those chains with the cams that you even use one of those tool in, I use chains that fit and a couple of bungees on them.
    ur2ez83 and Tx Countryboy Thank this.
  10. okiedokie
    13,684
    107,861
    Jun 13, 2011
    PNWET
    You probably don't use gloves, wear a tee shirt and tennis shoes. LOL Just poking the bear star.
    Cat sdp Thanks this.
  11. AModelCat
    163,685
    Shouldn't even need bungees if you got a good set of Trygg triples. Get 'em on there snug and they ain't coming off.
    James j Thanks this.
