Torque/Hp bump up.
Discussion in 'Volvo Forum' started by Socal Xpress, Mar 7, 2016.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Who has done this to there D13? I am not looking to go extreme just looking to get more torque. Currently 425hp 1450tq with 665k 10 speed. Ideally looking to get 1650tq but care more about reliability. Would 1550tq be a better compromise? Your input would be greatly appreciated.
    Also any recommendations on Dealership or a shop?
  3. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Volvo's engine software is their own and no one can just go in and change a few setting and bump it up
    1st only a volvo dealer can do it.... no diesel doctor, no outside shop
    2nd BIG BUCKS
    the dealer will have to check with Volvo to see what all the specs are for your truck... max torque for things like the clutch, trans, diff's. u joint's everything.... cooling ability, turbo size.... takes a few days for them to check.... then the dealer can tell you what you can change it too... max hp for a d13 in a truck is 500 max torque is 1,750....
    reliability should stay about the same..... Volvo woun't let you go over what your drive train can take
    engine software upgrade run $500-$1500..... this is reprograming the ecm with all new software with the setting needed for it to run at the new level
    KB3MMX and DustyRoad Thank this.
  4. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,105
    Feb 23, 2011
    Gulf of Mexico
    Maybe you should drive the vehicle as it was designed to be driven.
    Then again....
    You may want to buy a custom built 650 HP 2150 Lb tourque Cummins and drop it in a Glider.
    The difference between men and boys is the price of their toys.
  5. flood
    4,168
    4,047
    Dec 25, 2010
    a d13 can be set up to 900 hp with the factory twin turbo setup.... just not in a truck
    same as a d16 in a 780 max hp is 525, in a 880 max hp is 625, over seas a d16 max is 750 hp..
    KB3MMX Thanks this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Look up the guys at PDQ diesel performance.....the D13 will really uprate
    flood and Socal Xpress Thank this.
  7. Offroadjack
    Offroadjack Light Load Member
    197
    52
    Jun 19, 2012
    What year? I have a 550hp ecm for sale for 08-09
  8. flightwatch
    flightwatch Road Train Member
    1,249
    1,250
    Jun 22, 2011
    Somewhere in Texas
    Only up to ym '13 according to their website.
  9. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    KB3MMX Thanks this.
  10. Offroadjack
    197
    52
    Jun 19, 2012
    I left in the hollowed out dpf filter its just as quite as stock and looks like its never been messed with and I run out to cali.
  11. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I have a pdq power box for the D16 & D16 trucks for sale.....It's the Blixxon unit... PM me...
