TRAFFIC >:( (tips for me)
Discussion in 'Questions From New Drivers' started by Jbeltran805, Oct 9, 2016.
  1. Jbeltran805
    Jbeltran805 Light Load Member
    130
    55
    Jul 24, 2016
    So , I am not that good at downshifting a 10 speed yet, Upshifting is good.. but I get so #### nervous when I get traffic specially in big cities LA FOR EXAMPLE.. I did okay the first time, but I stalled it once because I forgot to put the selector down.. was pretty #### embarrasing.. so what are the tips for driving in real heavy traffic? with a 10 speed (freightliner tractor)
    Lepton1 Thanks this.
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Know your split break. I.e. above 25mph leave the selector up, below 25 trip it.
    Leave a huge gap in front of you so you can maintain a gear at almost all times, who cares if someone cut in front. There will always be someone in front of you...
    x1Heavy, Thull, TripleSix and 2 others Thank this.
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Best tip? Learn from your mistakes. Don't keep making the same mistakes. Experience is your friend. Eventually shifting will become as natural and automatic as breathing but until then remember that .. if it messes up when you do that. Don't do that.
    Learn to skip gears in the process of refining your up/down shifting skills, especially when empty or light.
    BlackThought and Jbeltran805 Thank this.
  5. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,679
    12,757
    Dec 15, 2014
    Charlotte, NC
    Listen to the truck and feel the RPM's. You will eventually know where the sweet spot is.
    Jbeltran805 Thanks this.
  6. TROOPER to TRUCKER
    7,679
    12,757
    Dec 15, 2014
    Charlotte, NC
    Oh also remember generally 35 is 8th, 25 is 7th and 15 is 6th
  7. Jbeltran805
    130
    55
    Jul 24, 2016
    what about the low gears 5-1?
  8. TROOPER to TRUCKER
    7,679
    12,757
    Dec 15, 2014
    Charlotte, NC
    Get down and get out. You may need to tal the gas it it will not go in. Just like when up shifting you get in and out of the low gears.
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Try to drive without using the brakes. Give yourself plenty of space so you can downshift to slow down. It will give you a better chance of bieng relaxed while your practicing shifing.
    City traffic is city traffic and you won't be going anywhere anytime soon so just try to relax and take it easy. Let everyone pull those tricks to get ahead of the next guy so they can sit at a red light when they get to their exit. :rolleyes:
  10. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    Say the gears out loud as you shift....sort of reinforces your memory of what gear you are in. Say "low five", or "high six", etc. might help, might not.
    For Your gear selection you can use this trick. It does help:
    15 mph = 6 th gear. (1 + 5 = 6th)
    25 mph = 7th gear (2 + 5 = 7th gear), etc.
    35 mph = 8 th gear
    45 mph = 9 th gear
    So you just check your speedometer and you can quickly add together your speed to see what gear you need. I still use this after a year of part time driving.
    With practice you will get much better with your shifting...after 25,000 miles of driving you will be much better at shifting.
    Jubal3 and diesel drinker Thank this.
  11. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    You'll probably just get better with practice.
    I suck at shifting for a few days when I switch trucks and I'm awesome.
    diesel drinker Thanks this.
