Trailer abs light woes
Discussion in 'Ask An Owner Operator' started by Codycodycody11158, Jan 14, 2024.
  1. Codycodycody11158
    Codycodycody11158 Bobtail Member
    46
    46
    Oct 27, 2020
    Hey fellas! Hopefully everyone is staying warm with this freezing weather! I really need some help on a used trailer I just purchased!!
    so, I have a 2017 cascadia , and just purchased a 2016 Dorsey flatbed. Well, with ignition on the light cycles like normal. When driving my trailer abs light comes on every time I hit the brakes. Also, it blows fuse “14 I believe. Trailer abs ignition on my truck.
    I’ve taken the trailer to two shops. First shop had it two weeks and said nothings wrong with it.
    second shop had it a few days and fixed some wires that were shorted. I went to pick up the trailer, and it had the same issue. They had it another day, and then said it was done. The trailer had a bad relay.
    I dropped the trailer off a few miles down the road and it worked fine.
    Now I’m going to pick up a load and have the same issue. I did just put in a new abs valve because the old one was leaking.
    Is there anything I can check or do before I take it to a shop for the fourth time?
  3. dosgatos
    dosgatos Medium Load Member
    582
    1,273
    Sep 18, 2012
    abs light on the trailer or the one on the dash? What brand is the trailer abs system? I have Bendix and downloaded the pdf manual for my version. It shows how to get the blink code from the trailer module and read the error. Image is screenshot as example. If the blink code suggests system is working properly the issue is probably the wiring upstream
    silverspur and Codycodycody11158 Thank this.
  4. Codycodycody11158
    46
    46
    Oct 27, 2020
    Abs light on dash comes on every time I hit the brakes. It’s a bendix unit.
  5. dosgatos
    582
    1,273
    Sep 18, 2012
    google bendix abs trailer blink code. bendix.com
    Codycodycody11158 Thanks this.
  6. Codycodycody11158
    46
    46
    Oct 27, 2020
    Yes sir, I’m becoming familiar with it unfortunately lol. Electrical issues are not my strong suit haha
  7. Codycodycody11158
    46
    46
    Oct 27, 2020
    I’m not sure I can start the blink codes. When I press my brakes I blow the abs ignition fuse. Ugh
  8. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    951
    1,844
    Dec 15, 2021
    You swap the trailer power cord around,or swap it with another one if you have a spare,see if that changes anything.
  9. Codycodycody11158
    46
    46
    Oct 27, 2020
    I don’t think it’s the plug, I was pulling a different trailer earlier this week with no problems with abs
  10. JonJon78
    JonJon78 Road Train Member
    7,214
    42,434
    Jul 1, 2018
    What did the first shop do with the trailer for two weeks?
    And
    Are these two shops just random trailer repair places or actual Dorsey dealers?
  11. Codycodycody11158
    46
    46
    Oct 27, 2020
    First shop was a local shop. They hooked up the diagnostic equipment and said everything was working properly.
    second shop was a really well reviewed local shop. Not a Dorsey shop.
    JonJon78 Thanks this.
