Trailer ABS out a citable offense?
Discussion in 'Trucking Industry Regulations' started by AdamT2k, Feb 17, 2010.
  1. AdamT2k
    AdamT2k Light Load Member
    120
    43
    Feb 6, 2009
    Minneapolis, MN
    Quick question...if you're lugging a trailer with the ABS light on, are you at risk of being cited for it? Just curious since my trailer ABS light comes on every time I hit a good bump and usually resets when the ignition is switched off. Thanks.
  3. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    I can only go by what the bears have done to me, but they have just written a 'fix-it' ticket. I had a sensor that wouldnt stay in adjustment, so ya go back there and push it in and turn off the switch and then its fixed. I asked why he wrote the ticket, he said if the trailer is equipped with safety equipment so its supposed to work. He did not put a FMCSA rule book paragraph/line number since it wasnt a violation. Sometimes I wonder if they just imagine stuff up so they can put it on so it looks like they worked really hard that day. I think if they really want to make it look like they are working, they need to start calling insurance companies to verify that these 'questionable' truck companies have insurance. OOPs, now that was off subject.
    AdamT2k Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    In Ontario, there is nothing that specifically say "ABS" systems must work. But it does say that any system related to or part of the brakes must be in working order. If we do a safety inspection, the ABS must be working.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    take the bulb out of the light
    NWAF, Dharok, 6daysontheroad and 3 others Thank this.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    some d.o.t.'s will give you a citation no matter what. the law'a reguarding truck drivers, is questionable. some are. for example. a d.o.t officer is giving you a truck/trailer inspection... one thing he will ask while checking your lights is, turn on your headlight's, next turn on your high beams. now if your high beams do not work he will write you up. however if you use them & he see them, he will write you up. using high beams in most states are a lot of points against your license. dont make sense to me.. if this device is not operational. a fine. if you use device, a fine? though I was just thinking about my last post.. if you remove the bulb out of the abs, he might write you up cause the light dont work. lol
    JWV and Dave_in_AZ Thank this.
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    If the DOT officer is knowledgeable of trailer ABS systems he will know the light is supposed to come on when the key is turned on for a self test. No light means system isn't working.
  8. amdriven2liv
    amdriven2liv Bobtail Member
    38
    10
    Feb 13, 2010
    Oregon
    From what I read in CSA2010. ( there is a good chance I can't read) You get 4 points if the amber light at the end of the trailer doesn't work at all. Like Heavyd said, test the light, light comes on then goes off, good.
    Light doesn't come on at all, 4 points to you.
    Light stays on, Carrier gets all the points.
    I am now carrying a list of violations in my truck just in case some Officer wants to write it up. Also to help interpret the rules with them. :)
    http://csa2010.fmcsa.dot.gov/Documents/SMSMethodology.pdf
  9. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
  10. dieselbear
    dieselbear Road Train Member
    1,798
    2,800
    Oct 18, 2008
    §393.55 Antilock brake systems.
    (a) Hydraulic brake systems. Each truck and bus manufactured on or after March 1, 1999 (except trucks and buses engaged in driveaway-towaway operations), and equipped with a hydraulic brake system, shall be equipped with an antilock brake system that meets the requirements of Federal Motor Vehicle Safety Standard (FMVSS) No. 105 (49 CFR 571.105, S5.5).
    (b) ABS malfunction indicators for hydraulic braked vehicles. Each hydraulic braked vehicle subject to the requirements of paragraph (a) of this section shall be equipped with an ABS malfunction indicator system that meets the requirements of FMVSS No. 105 (49 CFR 571.105, S5.3).
    (c) Air brake systems. (1) Each truck tractor manufactured on or after March 1, 1997 (except truck tractors engaged in drive-away-towaway operations), shall be equipped with an antilock brake system that meets the requirements of FMVSS No. 121 (49 CFR 571.121, S5.1.6.1(b)).
    (c)(2) Each air braked commercial motor vehicle other than a truck tractor, manufactured on or after March 1, 1998 (except commercial motor vehicles engaged in driveaway-towaway operations), shall be equipped with an antilock brake system that meets the requirements of FMVSS No. 121 (49 CFR 571.121, S5.1.6.1(a) for trucks and buses, S5.2.3 for semitrailers, converter dollies and full trailers).
    (d) ABS malfunction circuits and signals for air braked vehicles.
    (d)(1) Each truck tractor manufactured on or after March 1, 1997, and each single-unit air braked vehicle manufactured on or after March 1, 1998, subject to the requirements of paragraph (c) of this section, shall be equipped with an electrical circuit that is capable of signaling a malfunction that affects the generation or transmission of response or control signals to the vehicle's antilock brake system (49 CFR 571.121, S5.1.6.2(a)).
    (d)(2) Each truck tractor manufactured on or after March 1, 2001, and each single-unit vehicle that is equipped to tow another air-braked vehicle, subject to the requirements of paragraph (c) of this section, shall be equipped with an electrical circuit that is capable of transmitting a malfunction signal from the antilock brake system(s) on the towed vehicle(s) to the trailer ABS malfunction lamp in the cab of the towing vehicle, and shall have the means for connection of the electrical circuit to the towed vehicle. The ABS malfunction circuit and signal shall meet the requirement FMVSS No. 121s of (49 CFR 571.121, S5.1.6.2(b)).
    (d)(3) Each semitrailer, trailer converter dolly, and full trailer manufactured on or after March 1, 2001, and subject to the requirements of paragraph (c)(2) of this section, shall be equipped with an electrical circuit that is capable of signaling a malfunction in the trailer's antilock brake system, and shall have the means for connection of this ABS malfunction circuit to the towing vehicle. In addition, each trailer manufactured on or after March 1, 2001, subject to the requirements of paragraph (c)(2) of this section, that is designed to tow another air-brake equipped trailer shall be capable of transmitting a malfunction signal from the antilock brake system(s) of the trailer(s) it tows to the vehicle in front of the trailer. The ABS malfunction circuit and signal shall meet the requirements of FMVSS No. 121 (49 CFR 571.121, S5.2.3.2).
    (e) Exterior ABS malfunction indicator lamps for trailers. Each trailer (including a trailer converter dolly) manufactured on or after March 1, 1998 and before March 1, 2009, and subject to the requirements of paragraph (c)(2) of this section, shall be equipped with an ABS malfunction indicator lamp which meets the requirements of FMVSS No. 121 (49 CFR 571.121, S5.2.3.3).
    JustSonny Thanks this.
  11. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    Wire up your ABS wire in your tractor pigtail to a switch in the dash. ABS working normally- leave it on. ABS light comes on- turn switch off- light goes off. Inspected? Turn light on, turn light off. Easy.
    123456 Thanks this.
