Trailer bearings
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by drewfarmsllc, Dec 8, 2024.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    84
    32
    Oct 18, 2008
    South Carolina
    2010 walbash van. Self inflation system. Grease in bearing hubs. How do you know how much grease is enough? I bought the trailer used but dont know how to check the grease. I use an infared thermometer to check temp and they are close to same in temp but they could be all high. Of course this changes with ambient temp and load so i just dont know. Any ideas???
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    How long (miles) have you been using trailer?
    Only way I know to check grease hub is remove hub cap.
    Iamoverit Thanks this.
  4. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    What temps are you getting now? If the caps aren't too hot to touch with a bare hand I wouldn't worry about it.
    xsetra Thanks this.
  5. drewfarmsllc
    84
    32
    Oct 18, 2008
    South Carolina
    They are not to warm to touch. Kinda figured they are ok just didnt how or when to check
    Thanks
  6. Big Road Skateboard
    7,084
    40,143
    May 2, 2021
    There's really no wat to check without disassembly. Definitely wouldn't hurt, but if you're checking temp often, the only other thing I would do is check play.
    Jack it up and back your brakes off. Use a tire bar under the outside tire and luft up. If your vearings are loose, you know right away.
