Trailer Brake System
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gyrodeputy, Nov 19, 2023.
  1. Gyrodeputy
    Gyrodeputy Bobtail Member
    19
    7
    Apr 16, 2018
    I am going to be adding trailer air brakes to my straight (specialty dump) truck.
    I have a couple questions about the systems.
    So far I know I need a MV3 Valve Assembly, a tractor protection valve -TP3, the glad hands and air lines.
    Behind the dash I have a manifold with multiple outputs with green lines. The tractor brake valve is a very old and basic 2 line unit Bendex 284726.
    1 thing for sure I can't confirm in the rules is if there is a requirement for a manual trailer brake actuator handle.
    2 Are there specific requirements for the colors on the air lines or can I use black?
    3 What am I missing?
    Any advise would be appreciated greatly.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    A trailer hand valve is not required.
    Black is fine.
    You need a tractor protection valve.
    Your old and my old are probably different. They used to use individual valves. PP1, PP2 and such.You could probably just add a valve.
    If you list your truck and serial number some others might be able to help you a lot more.
