Trailer light issue?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thetrashnoob, May 19, 2025.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    299
    57
    May 30, 2019
    Having an issue with trailer lights on a new (to me) trailer
    I haven’t experienced this before and being a new owner op, need to learn.
    all the lights on the trailer work. Throw on 4ways the left side both side and rear lights flash. The right side side is on but no flash and rear right side no flash.
    In the last I’ve had to put tape around the plugs to make the connection tighter, could it be stupid simple as that? Or could be ground issues ect? I don’t belive that the light is burnt out as it was working a few months ago, but trailer has been sitting since
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Does the tractor work,but not the trailer or nothing on right side truck and trailer?
  4. SmallPackage
    5,777
    18,537
    Dec 20, 2019
    Marion Texas
    The 3 prong light connectors are finicky sometimes and don't make good contacts even if snapped on the light good. See it all the time. I think they corrode or break on the inside of the plastic where you cant see it. I’ve encountered many were just lightly wiggling a wire at the connecter makes them freak out. A lot of cheap ones they sell as replacement pigtails rot rather quickly too.
    Walk Among Us Thanks this.
  5. Thetrashnoob
    299
    57
    May 30, 2019
    All the lights work on the tractor.
    Left side and left rear of trailer flash.
    Right side light is illumined but not flashing
    Right rear not flashing or lighting up.
    I belive the light is good, can try swapping it. But believe something else is happening since the side light is illuminated just not flashing. If any of that makes sense?
  6. Ridgeline
    22,723
    123,063
    As with trucks, I will say this about trailers
    CHECK YOUR GROUNDS​
  7. Thetrashnoob
    299
    57
    May 30, 2019
    The grounds for everything or the specific light?
  8. sirjeff
    sirjeff Medium Load Member
    First thing I would do is pull your power cord out. The male pins (on the plug at back of cab, and plug on front of trailer) are slotted in the middle, use a pocket knife to spread em out a bit so they make tighter contact with the female pins on both ends of the cord.
  9. Big Road Skateboard
    7,076
    40,083
    May 2, 2021
    Pull the 7 way receptacle out of the front of the trailer. Make sure no wires are touching. Ground will be the larger white wire very top position.
    Oxbow Thanks this.
  10. D.Tibbitt
    156,840
    Get a test light. With the 4 ways flashing, test your 3 prong cable on the light that is not working. If no signal track it back to where u find signal.. usually from the light it will go into a junction box or something similar to that where your main cable will plug into.
    Iamoverit Thanks this.
  11. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    Test all pins on your power unit socket with a test light to rule out a wiring issue with the tractor. Next, move to the end of the pigtail while plugged in. Then plug the pigtail in and begin tracing wires on the trailer from there. You'll find it eventually. Test light are ridiculously cheap at Harbor Freight. You can also plug into a known working trailer to rule out pigtail harness or tractor issues.
