Trailer PM
Discussion in 'Ask An Owner Operator' started by Schöne, Jul 15, 2020.
  1. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    I haven't been an owner operator for a long time so I'm still learning things so pardon me if my question sounds stupid. Are you supposed to do a PM on a trailer? I know inspection is supposed to be done every year but should you service the trailer? Thanks
    USMC '74-'78 Semper Fi Thanks this.
  3. JonJon78
    JonJon78 Road Train Member
    7,240
    43,006
    Jul 1, 2018
    Grease all the zerk fittings, check conditions of air bags for cracking/dry rotted. Shocks for leaking. Brake pad thickness. Brake measurements.
  4. kemosabi49
    10,977
    47,914
    Jan 13, 2013
    SW Arkansas
    Your trailer need grease as often as the truck does, for one thing. Gets you underneath it if you do it yourself and you can see if any other problems are developing, like wheel seals,, etc
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Get the tandem rails and pins well lubed every few months. Nothing like getting stuck at a dock and not being able to slide the tandems because the rails are dry or a pin is stuck.
  6. abyliks
    abyliks Road Train Member
    4,110
    9,668
    May 2, 2010
    ludlow MA
    I grease+check brakes once a month, but I’m lazy and don’t drive much, and if you have to start wrenching on auto slacks it’s time to throw them away
  7. Schöne
    47
    20
    Feb 23, 2019
    Thank you so much
  8. bad-luck
    bad-luck Road Train Member
    3,430
    6,318
    Nov 16, 2013
    Baltimore, Maryland
    Yes, grease every 2 weeks
  9. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Walmart has inexpensive grease guns and grease tubes. I buy the red. Every 10k - 15k miles I go underneath the cart and apply the grease into zerks and as needed to the landing gears. I never applied the grease on the sliding rails but sprayed it with WD40. But maybe I'll try to give it some grease too.
    Lubing the trailer gives an opportunity to see brakes and hear air leaks too.
    I think Speedo charges extra for this simple effort.
    Since I've started doing PMs at Sapp Bros, it is included. I did PM there yesterday and paid $270 with a trailer lube included.
    I still lube the trailer in between PMs.
  10. SmallPackage
    5,777
    18,546
    Dec 20, 2019
    Marion Texas
    Unhook and check the king pin and bolster plate. Make sure they are not loose or rotting thru. Tap around on it with a hammer but dont ding up the pin. A welders chipping hammer works good for this on the sketchy looking rusty areas to see if it breaks thru the steel. Leaky vans and flatbeds well rot from the topside under the floor. You can’t easily see it. A friend of mine had the pin welds come loose from the plate on his old aluminum flatbed that spent it’s early years in the rust belt. Everytime he came to a stop he felt a push and when he left from stop the trailer would tug. Got bad enough to see the difference in the mirrors.
  11. USMC '74-'78 Semper Fi
    USMC '74-'78 Semper Fi Light Load Member
    134
    133
    Nov 13, 2013
    Mount Union, PA
    Thank you for asking your question. I think a lot of good advise has been shared. Tks
