Trailer slacks adjusting too much
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bowtieboy77, Apr 24, 2018.
  1. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I am a municipal mechanic working on a 3 axle RGN. When it was new it came with front axle using size 30 reg stroke full chambers and rear 2 axles used 30 reg stroke service chambers and gunite style slacks. Last year I converted all 3 axles to long stroke and installed meritor asa style slacks only they where fleetrite brand. A few days later got a call the front axle brakes where locking up. Sure enough brakes had over adjusted on front axle and where starting to over adjust on the 2 rear axles. I brought it to shop and was able to get the template out of a meritor asa slack we had in stock. I used the trailer template and adjusted the chamber rods as required. I kept track of it throughout the summer and it was much better but would still over adjust after a few weeks. The trailer gets parked over the winter and I am now doing the annual to prepare for the construction season. I will be double checking the rod lengths again but also wondering if the problem could be the fleetrite brand slacks and if I should just order 6 meritor asa slacks. I have researched meritor info and it looks as I will require the asa slack with the yellow band for trailer with size 30 chambers but there is no marking on the fleetrites and was no install info either. Also wondering why the front axle the one with the full chambers are over adjusting more then the rear 2 axles.
    Also does anyone have a preference as to what brand slack works best on trailers eg meritor, gunite etc.
  3. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    So did the original setup have any issues?
  4. bowtieboy77
    274
    82
    Aug 16, 2013
    Southern, Ontario
    The issue it had before was with the brakes adjusted to spec (tighten then back off 1/2) would give me 1/2" wrencch pull but when brakes where applied the stroke would be very close to 2". If I set them tighter being a low boy it had a tendency to lock up tire when empty. It was like this since new so play in bushings or pins is not the issue. This was the reason for the conversion to long stroke gives me a extra 1/2 " of stroke.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Do these trucks do a lot of stop/go and/or run a lot of hills? Back when I worked on garbage trucks in the mountains, we could not use Meritor slacks. They adjusted too quick on trucks that used their brakes a lot. What happens is that the drums heat up and expand without sufficient time to cool down, so the slacks adjust to compensate. When they finally do cool down and the drum contracts, they are too tight.
    For those extreme applications, Bendix slacks are better because they are slower to adjust. Meritors works great in most applications, just a little too quick to adjust with brakes that constantly run hot. If you take the slacks apart, Meritor pawls have much finer teeth, so it doesn't take as much slack to kick it a notch. The Bendix have courser teeth, so they need a little more slack before they adjust.
    BoxCarKidd and Jazz1 Thank this.
  6. bowtieboy77
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I have been kinda suspecting a similar idea. Its a rgn float that hauls our equipment to each job. Drive time from shop to jobs is mostly less then an hour. The operator that runs it ( the term operator is being used very loosely) is a clutch and brake style driver. Gearing down is a skill set he is lacking. I have been suspicious since every time the float gets split the parking brakes are applied and brakes will adjust alittle each time aswell as during break applications on the way. Also as mentioned the gunites that were on it stayed in adjustment just was always close to the 2" limit. Think I might order a pair of bendix and install them on the front axle and see how they do.
  7. bowtieboy77
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Grapeape would you have a model number by chance? I did a google search and found a bendix versajust LS. Will measure what I need and will be calling our IH dealer to source some. Thanks for the help.
  8. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    Versajust LS are the ones we used on the garbage trucks.
    bowtieboy77 Thanks this.
  9. bowtieboy77
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Ok thankyou I have 2 on order. I will see if this solves my issue. If so I will order 4 more. Thanks.
  10. Brake_guy
    Brake_guy Bobtail Member
