Trailer Tire help please
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stylez80Nine, Jun 9, 2022.
  1. stylez80Nine
    stylez80Nine Light Load Member
    185
    58
    Dec 2, 2018
    So I got a wabash trailer and it got continental 295/75R22.5. I got a good deals on some Goodyear 11R22.5. Can I put the 11.R22.5 on this trailer or is it going to give me issues. Thanks in advance.
  3. bad-luck
    bad-luck Road Train Member
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    You can't mix them, you have to replace all 8. 11r22.5 is a bigger tire, so your trailer height in the back would increase. You would need to check the rear trailer height. Obviously if it is already 13 6" you don't want to go with an 11r
  4. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    If you are air ride it's easy enough to lower ride height a touch to make up the difference.
    And there really isn't a reason you couldn't run lo-pro on one axle and talls on the other
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Only way a van trailer goes near 13’6” is with 11R-24.5’s. Should only be 13’4” or so on 22.5’s.
    Another Canadian driver and Oxbow Thank this.
  6. SmallPackage
    5,773
    18,530
    Dec 20, 2019
    Marion Texas
    Sizes and Specs | Goodyear Tires
    11’s are a full inch taller. They will have to be paired together on a different axle. Do not mount them on same hub with a 295.
    Keep in mind size variance is different among different makes. So a GDY 11 could be different dia. from a Mic or BFS 11’s. Gdy 295 can be up to 3/4” dia. different from other makes 295’s as well
  7. bad-luck
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    Technically you could do one axle, but it is not a good idea. One the tires on axle will be spinning faster than the other, which will wear out the tires faster on one axle.
  8. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    It's a trailer, the axles are not connected in any way. If the front axle tires are spinning faster than the rear axle tires neither axle cares
    haycarter and God prefers Diesels Thank this.
  9. SmallPackage
    5,773
    18,530
    Dec 20, 2019
    Marion Texas
    Yep. Like said trailer axles don’t care. But it is recommended that they are staggered if need be to keep the axles from trying to steer the trailer in a direction other then straight. If that makes since. If you put the taller ones on one side it will push the trailer towards the shorter side like a rolling cone does.
    AModelCat Thanks this.
  10. bad-luck
    3,426
    6,311
    Nov 16, 2013
    Baltimore, Maryland
    I am aware of that, but you didn't read what I wrote. If one axle is traveling faster than the other, the tires on the faster axle are going to wear out faster. A lot of guys replace all 8 when they need tires.
