trailer tires
Discussion in 'Experienced Truckers' Advice' started by AM77, Mar 18, 2012.
  1. AM77
    AM77 Light Load Member
    171
    47
    Sep 17, 2011
    Chicago, IL
    some areas on couple of trailer tires are being "eaten alive", while other areas are still like new.. WTH is going on? :biggrin_25510:
  3. Ruges
    Ruges Light Load Member
    190
    70
    Feb 6, 2010
    InMyTruck, USA
    When you turn, exspecialy a tight U turn, even backing at tight angles, your trailer tires are not so much rolling but sliding sideways across the pavement. These cause flat spots and imbalance which further compounds the issue.
  4. AM77
    171
    47
    Sep 17, 2011
    Chicago, IL
    Ruges, thanks for reply. I have done few years of local work where i had to back up into a dock some 20,30 times a day and i've never seen tires being worn off in such an unusual way. Problem that i have has happened in rather short period of time.(4-5 months)
  5. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    when making u turns take your time, its not saying that you are insecure,its saying hey look at me i like to take care of my stuff
  6. Ruges
    190
    70
    Feb 6, 2010
    InMyTruck, USA
    Same axle spread, kingpin to axle distance, weight on the axle? If you dont think its from turning it could be an alignment problem, have your trailer aligned next chance you get.
    AM77 Thanks this.
  7. AM77
    171
    47
    Sep 17, 2011
    Chicago, IL
    no u-turns here, i avoid them at all costs:biggrin_25513:
  8. AM77
    171
    47
    Sep 17, 2011
    Chicago, IL
    i do think i should take it for alignment...thanks ruges
  9. Wargames
    Wargames Captain Crusty
    3,279
    7,509
    Jul 22, 2010
    WI.
    Everyone has a good answer, but I can gaurantee you Its your brake cams. A few years ago, I had the same thing happen, high spots, the low spots all around the tires. I called the company office, and got another trailer for a few days, the finally got mine back, looked under the trailer, had all new cams, never happen again.
    AM77 Thanks this.
  10. Lonesome
    Lonesome Mr. Sarcasm
    11,690
    24,369
    Dec 15, 2007
    Northern Indiana
    Spread axles are notorious for wearing tires. Otherwise, check the alignment.
    AM77 Thanks this.
  11. Mr Ed
    Mr Ed Road Train Member
    1,380
    1,630
    Apr 6, 2009
    Retired in Taunton Ma
    Actually, I stoled your good tires and replaced them with my crappy ones.Hoped you wouldn't have noticed so quickly.
    AM77 Thanks this.
