Trailer weight
Discussion in 'Canadian Truckers Forum' started by ganja24, May 3, 2020.
  1. ganja24
    ganja24 Bobtail Member
    15
    In Ontario what is the max legal weight that can be loaded on 53ft dry-van tandem? Driving day cab.
    Is there a MTO link I can show to dispatch max weight limit for 53ft tandem trailer?
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    aaronpeterbilt3787 Thanks this.
  4. AModelCat
    163,949
    No cut and dry answer on this one as the tare weight will vary from truck to truck and trailer to trailer.
  5. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    699
    1,077
    Apr 2, 2016
    Scale your unit empty, then look at your cab card for your registered weight. Do the math. As far as axles, you can legally go 5500 steers, 17900 on drives and trailer tandems. In KG of course. And as long as you’re registered for 41300kg. Which is max I do believe for Ontario. With a tandem.
  6. ganja24
    15
    Dispatch gave load with 55000lbs, said it’s legal. Another driver tells me 44000lbs is legal, dispatch is wrong. Even though I was not taking the load, I want to know who is right. Sorry might be stupid question as I just shunt. As a shunt driver I trust the driver and want correct the dispatch with proof.
  7. aaronpeterbilt3787
    699
    1,077
    Apr 2, 2016
    You can probably scale 55 in a day van no problem. I take 54-55 lbs all the time. And I have a sleeper truck. Just be sure to scale it.
    magoo68 Thanks this.
  8. rzl-dzl
    rzl-dzl Medium Load Member
    477
    175
    Dec 16, 2011
    100 mile house
    this
    we took 44,000 # to the states all the time, in reefer trailers.
    dryvan way lighter, and canada gross weight higher than usa
    BigHossVolvo Thanks this.
  9. REALITY098765
    REALITY098765 Road Train Member
    1,520
    1,350
    Sep 17, 2017
    It's been a while that had to worry about weight in CAN, I thought at least in ON with a 72 in spread you could go 44000lbs per tandem.
    44
    44
    13
    111000 gross. in theory but I'm sure there is a caveat somewhere.
  10. aaronpeterbilt3787
    699
    1,077
    Apr 2, 2016
    All depends on what you’re registered for. I know what I’m registered for in Ontario. And no way I can scale 110000 gross. Axle spread or not.
  11. REALITY098765
    1,520
    1,350
    Sep 17, 2017
    Registered for 140,000 gross for doubles.
