Trailers & Bridges - Trailer Height
Discussion in 'Experienced Truckers' Advice' started by Grumppy, May 21, 2018.
  1. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    Regularly, we have new threads started here about accidents with trailers & bridges/overpass's/trestles. We all know that 13' 6" is the normal & legal height for lines, bridges etc for truck routes etc.
    I've experienced & been under a 13' 7" trestle, some one has posted they've gotten under a 13' 0" I believe.
    My question for discussion: How high is your trailer? What is the lowest bridge etc, that you have cleared? I mean, really.... what is too low in your personal experience? If you see a 13' 5" are you gonna try it? How about a 13' 3"?
    Its obvious that trailers are not 13' 6"... so how high are trailers generally? How high is yours?
    Lets try to keep this to dry vans, refers etc. We know your lowboy aint an issue here.
  3. stwik
    168,095
    Mid roof open deck. I’ve snuck under a few 12 footers in the DC area...
    I want to say my T660 comes in right around 11’-5” but I won’t go under anything less than 12’ on a good day...
    Opendeck and x1Heavy Thank this.
  4. kemosabi49
    10,977
    47,915
    Jan 13, 2013
    SW Arkansas
    I was in Chicago and had to go under a RR bridge posted at 13'3". I made it crawling through, then later I actully measured my rig. With lo-pro 22.5 tires I was 13' 3and 1/2 ". The clearance posted on bridges is often the lowest point. Sometimes it is higher on one side than the other.
    I read where standard van trailers are 13'6" with a 47.5" fifth wheel height.
    x1Heavy Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I have done 13' 5" when airbags are dropped and loaded.
    There is a bridge off US 6 near Elmira Horseheads south of town itself that passes under a major east-west road (I forget exactly it's designation off hand.) that bridge has caused me some issues more than any really. Especially since they engineered so that the girders and bolted plates underneath are really seriously beefy. They claimed that one was 13.6 But when I show up, antennas at 13.5 singing, tapping exhaust pipe behind cab at 13.5 and crawled under without scraping loaded with no daylight up top. The condition of the pavement below has alot to do with it. Either winter slush, ice or snow makes a potential scrape (Gently... like a wife, pet that bridge gently) Or even more fun, summer heat expands the new pavement under there and you are back to scraping again. There were a couple joints in the pavement above and when heavy over size pounds on them it taps my trailer now and then. tap tap tap. Once out northbound into town proper I can breathe.
    After getting empty though on spring ride (No airbags anywhere) it becomes even more interesting.
    Tires HISSSSSSSS. Then crawl under on hot days. Break out the 50 foot airline with it's own trolley gladhand and air your trailer tires back up. That takes a while. Annoying too.
    The one bridge I used to say a prayer on would be north of Lancaster PA on US 222 southbound. It's a two lane road there. There is a stone arch bridge in them days across the entire roadway. SIGNS over the lane you are in say 10 foot flat. Other side says 10 foot something in their lane.
    Number one of 4 of us gets on radio, how bout you northbound. Stone arch bridge 5 souls in about 15 seconds, we are coming through. Hop into the middle over that double solid yellow dead center and ram through just missing your top corners all the way down by a couple of inches or so. No matter what happens to the cars around you do not sway your trailer. You must take it down the middle in straight line. That means the locals are going to take their cars onto the shoulders both ways when they see us coming down the middle with the double yellow pavement dividing line under our doghouses. Northbound big trucks hop onto the radio after the 5 of us shoot that arch bridge and say they are three souls coming through, southbound hold up a sec. And they will shoot the bridge. And it becomes southbounds turn again.
    It can be really intense and groovy I prefer to be either caboose or rocking chair, never ever number one on that route. Why? I cannot hear well on that radio. If I screwed up whose turn is it, we are going to have a one hell of a head on collision. Make that several trucks together. Smash.
    For all of our sakes I hope they replaced that bridge.
    Darlington Race track. has a ped overpass made of metal. Rusted beyond belief. Started to sag one day. I really hate to say this but I am one of the last trucks to pass under there some time before it went ahead and fell down with people up top who got hurt. Maybe killed too. I dindu. (Didnt do nuffing)
    Chester PA. There is a container port, a righteous one by the Delaware river. A really small, very fast top notch crewed port. I can switch chassis, containers in any combination and be gone in 40 minutes flat any time of workday. It's a little bit scawy when the container jacks with wheels as tall as your rig spots your truck with a loaded container matching the BOL in your lap wheel around and come after you with that big box swaying in the sky. YOUR job is to be in that yellow painted rectangle and STAY THERE with max brake application until the THUMP is over and done with.
    I don't know about you but those boys handled those jacks like a childs play thing box goes into your chassis perfect. Two honks later means you can now get out and get your corner pins. Now gtfo, others are waiting.
    There is one problem with that Chester port. There is a Philadelphia commuter line station right across street. Under those tracks is a hot neon pink painted and flashing lighted gaurded bridge saying 13.0 feet. All Trucks turn left only Never right. Trucks banned do not turn right etc. Stacks of signs covering that street corner in three different neon colors. Puke yellow, hot pink and bright lime green etc. No, no and no that means you and you and you and especially you.
    Here comes JBH with a full van trailer. He makes the right turn. Radio lights up HEY YOU ####### STOP THERE DON"T YOU MOVE!!!
    Too late SMASH. No more trailer, no more tractor. Driver falls out and staggers around with his bell rung.
    5 to 10 of us run up to him telling him what a stupid idiot he is doing that dumb wreck. Look at this mess you made.
    nospeakieenglish.
    Once or twice a week. SMASH. Over and over and over and over again. SMASH> SMASH SMASH.
    I hope PennDOT Bricked and concrete blocked that thing over so nothing will go through that way anymore. All they had to do is drive past there a mile then make a right to cross over a crossing. Disgusting.
    Dino soar and taodnt Thank this.
  6. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Even though I haul only open deck, I have a little tip...
    I use my CB antenna as a height indicator for my cab height...I have it exactly 6" higher than my cabs height. If I'm unsure, I'll crawl up to the bridge/trestle/whatever, and if that hits, I ain't chancing it...
    Truckermania and xsetra Thank this.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,978
    19,021
    Nov 1, 2010
    Burnsville, MN
    I was in NY and came upon a bridge with a 12'5" clearance.
    The sign was about 100 feet from the bridge, and me going 35MPH. My RM GPS had no clue.
    It was a lie.
    After nearly skidding to a stop I looked at it, then slowly moved under it.
    My 13'6" trailer had inches to spare.
  8. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I try only to go places that are marked 13 foot 6 or greater
    Unless you are in New York. In New York all bets are off because all of the bridges pretty much are marked incorrectly and you just need to know where you can go and where you can't.
    GirlFriday76 Thanks this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Standard trailer height is 13.2.
    There's some 14 footers floating around but I"m guessing they don't visit the eastern side.
    Grumppy Thanks this.
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Deleted
    Sorry,.. Not van or reefer. Disregard.
    Hurst
  11. TRKFreighter
    TRKFreighter Bobtail Member
    48
    15
    May 24, 2018
    A key tip for drivers is to lookout to identify upcoming bridges ahead of time. Once identified, pay attention to any signs indicating low clearance. If there is a pull-out detour designed for larger vehicles, adhere to it. Otherwise, plan for over-height clearances when visiting new areas by using your province's or state's traffic website or ask your experienced dispatcher.
