Train horns
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bdog, Dec 23, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    Both my air horns on the roof have holes rusted in them and no longer work. I was thinking of maybe train horns instead of just replacing them with the same ones.
    All the train horns I have been looking at have electrical connections on them which has me confused. Can't I just run an air line from the valve the operates my current horns to the train horns or do they need the electric switch for something?
  3. burnsey
    burnsey Light Load Member
    81
    40
    Jan 24, 2014
    seacoast, NH
    A lot of times those train horns need a _LARGE_ volume of air, and use a larger air line than your rooftop horns might use. The electric connection operates a relay that will allow all that air through the horns at once.
  4. Bob Trehus
    Bob Trehus Light Load Member
    91
    73
    Nov 4, 2015
    You can remove the electric solenoid in the center and replace it with 3/8 airline to a threaded connector then to a ball valve controller then to any air supply... I pull directly of my primary tank...
    chopper103in Thanks this.
  5. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    they will suck some air real fast
  6. Bob Trehus
    91
    73
    Nov 4, 2015
    This is true brother... Make sure you check to see how fast your air pressure drops... Some guys use a check valve to shut the air to the horn down before pressure drops under 90lbs...
  7. Bdog
    1,057
    877
    Nov 6, 2014
    That would suck - blow the horn and the brake valves pop out lol
    burnsey and chopper103in Thank this.
  8. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    Saw it happen....guy pulled his newly installed train horns while pulling away, and POP....Stall...."crank of shame"
  9. Bob Trehus
    91
    73
    Nov 4, 2015
    Truly not his coolest moment...
  10. Bob Trehus
    91
    73
    Nov 4, 2015
    The neat thing about using a ball valve over the electric solenoid is the much wider variety of sound that can be produced over the full on of the electric solenoid...
  11. Bdog
    1,057
    877
    Nov 6, 2014
