Transcraft
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cluck Cluck, Nov 5, 2011.
  1. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    I have a 48' 102" Transcraft Combo I'm having issues with the suspension......When there is no load on the trailer the airbags are in the "normal" position but when I gross out to 80k the trailer sits REALLY low and rides like crap, the bags are hard and full of air but It's like the suspension doesnt have enough power to lift the load into the proper position, I've changed the leveling valve and I cannot figure out why this is happening, I normally pull my SD so this doesnt need to be a huge hurry to fix just looking for suggestions
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Probably you have the 23K suspension which is pretty weak. I've heard of people putting 30K bags on the 23K and they work much better. Also heard the only difference between the two is the air bags. This is all hearsay i have never tried it.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I've never tried it with the Intraax but I know you can't easily swap the HT230 bags for the HT300. I've put 30k bags on a 25k but I think the bolt spacing is different for the 23k. On the 23k I had we ended up just adding a 3rd bag because it wouldn't pick the load up.
    Cluck Cluck is your suspension the HT series or Intraax? If your not sure the HT series has the brake chambers mounted in the middle of the axle tube close together, the Intraax has them mounted out by the tires. I'll check to see if the bags are interchangeable.
  5. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    Do you have a sliding rear axle on the trailer?
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Guys, he's is having this problem with only 80.000 lbs gross. 23,000 lb interaxx should have no problem picking that up. Only one thing that could be and that's not enough air presure in the bags. There is a regulator on the air tank that supplies the leveling valve it's supply air. I think I would start there.
  7. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    The brake chambers are out by the wheels, when I came out of SD I had 11600 on the steers 33800 on the drives and 33000 on the trailer, If I had a load on i'd post a picture, but I took 11000 to ND and it was fine, while its loaded the deck is maybe 4 inches max from the tires and when empty or really like it rides just fine....great actually, I'll check the regulator out of the air tank to the leveling valve, but if I take the valve and manually it wont lift it either
  8. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    it is a NON slide axle
  9. G/MAN
    7,031
    8,625
    Sep 3, 2010
    The reason I mentioned it is that if you don't flip the lever back it will not completely reinflate the airbags. Since that is not an issue, I would do as another suggested and check the valve.
  10. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Check presure at supply to leveling valve, should be no less then 90 psi.
    If it's not replace regulator, if good then change leveling valve.
    You got to understand that your suspension is rated for 23000 lbs per axle. So technically your good for 46000 lbs and you only had 34000.
    So tell me, Do you really think you need bigger bags?
    You should be able to put 80000 lbs on the deck and have no problem.
    Mind you the local dot will. LOL!!:biggrin_2556:
  11. Dino1968
    Dino1968 Light Load Member
    Try what the other 2 posters are saying. There is a PPV[ pressure protection valve] that usually has pipe threads on it and it threads into your air tank. Follow the supply line from your leveling valve, it will be where the line goes into the tank. Take your supply line off, unthread the PPV, go to dealership, get new one, replace fitting from old to new. Shouldn't be more than $30-$4o for the new one. The PPV is there too keep a busted or badly leaking airbag from draining your system of air. [And believe me it would]. These things get old and plugged up, most cost efficient way is replacement.
