Transmission cooler question.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by circle h, Jul 21, 2022.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    I have a 2004 KW W900 daycab with a Cat C-12 and a rto16910cas2 transmission. I don't know the rear ratio of the top of my head, but in tenth I'm doing 1500 at 60. The truck previously did a lot of hours with a pto. I have removed the pto and am using it as a farm truck hauling grain. I was just about to pull the transmission and replace the clutch. It has a water to oil trans cooler. I suggested to my son that we change it to an air to oil cooler so we could never have a water in the transmission disaster. He asked why we would even have a cooler with the pto removed.
    So my question is do I need to have the cooler hauling 80k 20 miles and 30k coming back all day?
  3. Diesel Dave
    9,618
    32,386
    Jan 20, 2010
    Hesperia, Ca.
    I bypassed mine cuz it sprung a leak. I just keep an eye on the temperature.
    Bean Jr. and circle h Thank this.
  4. lester
    2,956
    8,077
    Jan 2, 2012
    NW, Iowa
    No you don't need a cooler
  5. circle h
    240
    375
    Oct 22, 2020
    Thanks for the answers. It took my kid to say "we don't have coolers on any other trucks" for me to think about it. Simple is better in my mind.
    Bean Jr. and Diesel Dave Thank this.
  6. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I’d think the only time that transmission would build up any amount of heat would be loaded in overdrive for hours on end. Watch the temp but you should be fine with no cooler.
    Big Road Skateboard and circle h Thank this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    No you don't. Those short trips it won't even get above 130 I bet. I don't have a cooler on a RTOO 14613 and even in the big hole it will stay about 190-195 on a hot day running up around gross
    circle h Thanks this.
  8. circle h
    240
    375
    Oct 22, 2020
    Thanks for the input. I am going to eliminate the water side of the cooler. It will be easier than removing it altogether.
    Big Road Skateboard Thanks this.
  9. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    bud nobody can answer to your question. buy trans oil temp gauge kit and install it. monitor readings and you will find out cooler is needed or not...
