Transmission "feel" question
Discussion in 'Questions To Truckers From The General Public' started by Oso, Oct 19, 2010.
  1. Oso
    Oso Light Load Member
    217
    107
    Aug 6, 2010
    I hope this is the right forum for this....
    I've been in trucking school for a few weeks now and have had the opportunity to try a number of transmissions. I've tried a couple of trucks that are 3-6 years old - mostly Eaton Fuller 10 speeds. Some shift like buttah and have springs that line you up for 2nd/3rd and others are quite sloppy and/or unforgiving. So my question is this: why is there such a variation in feel?
    My other question is, is it possible to specify a nicer shifting transmission when spec'cing a truck? Does Eaton Fuller give you the ability to customize the "feel?"
  3. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    Most feel the same from the factory, but the abuse from drivers make each transmission feel different.
    Plastic gear lever bushings wear, and cause the sloppy feel.
    They just need to get them fixed....
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    I don't know about getting a spec's out smooth shift. All trucks will feel like they are shifting smoother when they have been serviced...meaning the mechanics tighten this lube that etc... the other reason why some of the trucks shift better than others is the amount of wear that the previous drivers have done to the trani and clutch. When you get your first truck from your employer( when you finish orientation and training) you get an opportunity to go over your truck. Drive it ...if it shifts like crap take it to the mechanics with the rest of your laundry list of issues that you find and ask them to readjust the clutch cause it shifts like crap.
  5. Allow Me.
    10,766
    12,578
    May 28, 2009
    Rancho Mirage, Ca.
    Every truck you ever drive will have it's own personality.
  6. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    Very true.....they are like people in that respect
  7. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    in general, trucking schools buy in "lots" of used trucks. this reduces the over all cost of buying equipment that get the shiot kicked out of it by students. the trucks my former (and current employer *both schools*) buy are from Ryder, Penske, maybe defunct trucking companies as well. heck, we even have purchased a few Con-Way trucks... most are single axle day cabs, 7, or 10 speeds. so they have been abused by the dozens of drivers over the years. the best ones however, become the "fleet pride" and are road tractors.
    if YOU as a driver were to go out and buy a brand new truck, YOU would be the only driver....YOU would treat the truck like gold, because YOU paid for it. a company driver couldn't give a rat's fat arse how he treats the equipment, if he breaks it, they put him in another one.
    if YOU break YOUR truck......YOU gotta pay for it, so it stands to reason YOU will take good care of YOUR truck. that transmission shifter should last hundreds of thousands of miles......
  8. Flying Finn
    Flying Finn Heavy Load Member
    972
    558
    Jun 22, 2010
    Ontario, Canada
    Every truck has a 'feel'. One thing I hate is going for a pre-hire test drive on a new engine/trans combo. It takes most drivers a couple of hours of driving to find most of the little quirks that every combo has. Some like higher shift points (my old Mack CH613), some like low shift points (the '08 Pete I was driving). If you stick with a 1500/1000 rpm range to hit then you can tweak it from there.
    Heck I never could get used to the truck my buddy I drove with for orientation (paperwork only) has. A '94 KW, CAT engine with a RoadRanger 15 speed. For some reason I just couldn't get used to the shift points. Maybe because they were all different depending on the load you had. I know the KW needed a new trans, I think he was going to drop an 18 in there. Would be really nice when that happens.
  9. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Every brand of truck has it's own shifter, with different bends, different legnth, different legnth of throws, or distance between gears. You can have the same transmission in each truck, and all change diferent because of this.
    How the was previous drivers drove will also have a huge effect on how the feel is. Different engines also will make changing different, as some rev up and down faster, some take fuel quick, others dont, some like high rpm changes, some don't. A Meritor or Rockwell transmission will feel completely different than an Eaton.
    kw18 and The Challenger Thank this.
  10. driver4015
    driver4015 Medium Load Member
    529
    189
    Jan 28, 2008
    Bend ,Oregon
    most transmissions come with the option of two "different" feels! these are, Take it or leave it! you get in the truck and drive the durn thing! for having over a million miles on it, the tranny in this truck is in pretty good shape, I can still tell when it goes to the high side. and I don't have to guess where the next hole is. Pretty lucky I guess. But this was the first truck my boss bought and it's been pretty well taken care of.
  11. Oso
    217
    107
    Aug 6, 2010
    Thank you kindly for the answers.
