Transmission yoke....
Discussion in 'Mack Forum' started by chalupa, Jun 16, 2011.
  1. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    The fuller 9 in the my dog has about 720k on it and it has a rumble pulling through 52 to about 62 mph. You can forget the radio during this time and it seems to be worst in the high gears. (8-9)
    When I grease it I check the play in the shafts and I found about 10k vertical in the front yoke. ( rear of tranny ) Old school tells me no sir.... should be a little thrust but no vertical play.........
    So I run it into the shop and the mech. gives it a clean bill. Says that play should be there for the miles........
    What say you ?????
  3. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    i had a mack single axle day cab ch model....
    my rumbling somewhat like you describe (and slight vibration) was actually from the rear end. company did not fix the problem, till the city driver blew it out climbing a hill....
    chalupa Thanks this.
  4. Kmack771
    Kmack771 Bobtail Member
    7
    Fort Myers, FL
    Check your ride height...
