Tripac apu primer pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 062, Feb 11, 2018.
  1. 062
    062 Road Train Member
    6,327
    33,967
    Oct 20, 2013
    My primer pump chose to take the day off. Anyone that's had one lose prime knows they're not the easiest to fire back up even with the pump working. I started messing with it trying to get it to fire up,but couldn't get it to run but maybe two seconds. I'm kind of stubborn,so I said this things not going to whoop me,after two hours I finally found a solution. Turn the inlet banjo fitting to the 9 o'clock position and reroute fuel line underneath the breather tube,this way the injection pump isn't pulling fuel up hill.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Thanks 062, I think I might have one going out to.
  4. WildTxn
    WildTxn Light Load Member
    115
    149
    Feb 19, 2018
    Also, check your fuel lines for cracks. Sounds like you have a "sucking air" problem. Also, your fuel filter may be clogged. I have several diesel generators, if one starts losing prime, there is usually something else wrong causing it.
