Truck Comparisons
Discussion in 'Trucks [ Eighteen Wheelers ]' started by badgerrents, Dec 1, 2014.
  1. badgerrents
    badgerrents Bobtail Member
    4
    Where can I go on the internet to compare freight liner, peterbilt, ken worth, mack, and volvo before a purchase?
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Out of that group i would only compare peter
    Bilt and kw they're in a class of their own
  4. SpankingGT
    SpankingGT Light Load Member
    253
    55
    Sep 9, 2010
    Those days are gone! Build quality is almost the same on all these trucks! Reliability should be the foundation of truck searching.
  5. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    You must own a harley then? Lol. Any truck with a decent motor makes money.
  6. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    start from the motor/trans/axle
    once you got htat decided. THEN worry about the plastic around it lol
  7. badgerrents
    4
    Any opinions on motor/trans/axle? Estimated maximum weight we will be carrying on a 48-51 foot trailer is 38,000lbs
  8. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    If you're buying new (2010+ emissions trucks) if stay away from anything powered by a PACCAR mx13 or Detroit dd13. We have those in our trucks and they are in the shop all the time. The Cummins ISX powered truck we have is the only reliable one on the yard.
    I'd recommend anything pre-2003
    russtrucker Thanks this.
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Depends on what one is looking for in an overall package. Each OEM has some unique things that can be done in spec'ing out a truck that the other's don't. You have to analyze what all you want in a truck, and then narrow in on who will put a truck together with all you want, then compare. Just brand comparison doesn't cut it.
    For example, and just an example for this discussion. International has an exclusive with Allison for the new TC-10 automatic transmission. If one was looking for that, then International is your only stop. If you are sold on the DT12, the Freightliner/Western Star is you only choice. You want a Detroit engine, same thing. There is a long, long list of similar type of things going on. It all depends on what you want in a truck. Then you have to go to the OEM's that do that. Axles, suspensions, cab/sleeper layout, etc. Every OEM offers something different than the others. It is a package kind of thing. Not like going down and comparing a Ford F-150, a Ram 1500, and a Chevy 1500. That is pretty limited. With a semi truck, you get to tweak things clear down to the brand of wheel seals to make it specifically fit you and what you are trying to do. You just can't reasonably compare trucks across brands when you do that.
    mp4694330, badgerrents and DrtyDiesel Thank this.
  10. uvulabruzr
    uvulabruzr Bobtail Member
    36
    13
    Nov 1, 2014
    CANADA...EH
    I've rebuilt a lot more Cummins engines than Paccar engines of the same year 2010-2013!
    Cummins get carbon packing in the piston rings causing them to burn oil, oh and they are dropping liners. only had the head off of one Paccar that dropped an injector tip... $0.02!!
    Personal opinion, buy what you like/want. stay away from the last Cats unless you have a truck load of $$$$!!
    badgerrents Thanks this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Anything you do start to consider, do searches on the Internet for forums just like this. Before I settled on my 2013 Westernstar DD15, I looked up on Volvos D16 and it scared the hell out of me at the time.
