Truck problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by David Neah, Sep 19, 2019.
  1. David Neah
    David Neah Bobtail Member
    5
    Does anyone what my problem is on my truck. Have a 2011 freightliner cascadia that sometimes don’t want to start . It will start when it’s cooled off but when I drive all day and turn it off . It won’t start. I have to let it cool off for a few minutes and than it starts. Does anyone else what it can be.
  3. TripleSix
    133,224
    The Starter is bad.
    FlaSwampRat Thanks this.
  4. David Neah
    5
    Already changed the starter . Nothing wrong with it . Also changed the clutch sensor.
  5. WiggleWagon
    WiggleWagon Light Load Member
    232
    312
    Aug 17, 2016
    Parked At The Fuel Island
    Is this a crank and no start, or no crank? Test the batteries too.
  6. TripleSix
    133,224
    New starter or remanned?
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Truck programmed to obey FMCSA rules. Break and time off.
    snowlauncher Thanks this.
  8. David Neah
    5
  9. David Neah
    5
    It cranks a little but stops
  10. WiggleWagon
    232
    312
    Aug 17, 2016
    I would guess check batteries/charging system. Older batteries tend to fail when temperatures start changing fairly dramatically. Just a guess though. Good luck.
  11. David Neah
    5
    The problem is I can drive for awhile. And than when I stop for a few minutes turn it off. Than try to start it doesn’t. I have to have the truck cool off for a few minutes and it starts right away.
